Re: Looking for help
Tom
I have used lighter power version of this on small fixed tools like grinders. It is kill switch that LV sells. There are certain things where the bad times keep on rolling when the scarf hits the fan. My best example was when I tried to use a spade bit in a drill press. I powered it up, and it instantly started to wobble. I hit the floor, but it would have been great if the bit rather than making like an aircraft prop and then snapping off, would have just powered down. I bought mine at LV:
http://www.harborfreight.com/momentary-power-foot-switch-96619.html
LV has these privacy mats, and they are like regular door mats, but when you step off your session is over on the computer. Something like that for a table saw, so you foot wasn't cranked at a bad angle would be great. If you walk off it turns off, but you still have a magnetic switch to use. A mag switch is another thing to install, they reset to off if the power goes out, or a cord gets pulled. So if there was such a mat, you could walk off, it would kill the saw, but the saw wouldn't turn on when you stood on the mat again.
Another thing that is a big issue is fluro lights that can sync with the moving blade and appear turned off when they are in fact moving. Make sure if he can't hear the difference that there is a flicker free source of light in the shop. I don't know if LEDs are flicker free, but regular light bulbs are. Dimmers can do weird things on flicker.
