Panel joint failures
All the glues commonly used to assemble panels are stronger than the wood. (This statement is only true at when the glue is not in a hot environment or a severely damp environment, both of which weaken most glues substantially.) Hence, stress on a glued up panel should fracture it at some location other than the glue joint.
If the joint failed there was some defect in the glue, machining of the joint or its assembly. The Franklin trouble shooting guide to wood adhesives lists more than a dozen ways that the process and materials of making the joint can be defective. I will describe 3 in addition to excessively damp and/or hot ambient conditions.
Insufficient clamping pressure to squeeze excess glue from the joint- If the glue is stronger than the wood why does a wide glue joint fail? The glue is a mixture of water and polymer particles, as I recall about 50% solids. When the water leaves from a fat glue line voids are created from the vacant space where the water used to be. Microscopic examination of the cured glue would reveal that it looks like Styrofoam, or empty honeycomb in the worst cases. While the glue remains strong the air bubbles holding the joint together are not.
Too long to assemble the joint- The open time for our common glues can be less than 5 min under hot or dry conditions. If the glue begins to dry before the parts are mated several bad things can happen that will prevent the mating surfaces from being wet by the glue and/or the particles in the glue from coalescing to form a continuous polymer film between the mating parts.
Glue applied to cold lumber- The glue forms a bond by water leaving the glue line and the particles of polymer that remain coalescing into a continuous tough film. The mass of the lumber is vastly greater than the mass of the glue, so it is the lumber temperature that rules, not that of the glue. To coalesce, the particles must be mushy. If they are too cold they are not suffieiently mushy. 55 degrees Fahrenheit is the lowest temperature that ordinary Titeboand can be used, for example. (Latex paint and Titebond glue are essentially the same physical materials, what in polymer chemistry is called a "latex". Apply the paint when it is too cold and the surface will be grainy because the particles have failed to coalesce. All the problems and precautions of painting apply to gluing, for the materials are similar )
