When we had our Ides of January survey a couple weeks ago, Keith mentioned his trick for drying and de-bugging air dried lumber. I thought it sounded like a good candidate for our articles department, so I got him to send in a few photos and further words of explanation. The result is now uploaded for your evergreen viewing edification. Have a look.
I like the band saw and jointer in the background. The jointer looks like a cresent that I used to have at the high school that I taught at. I got rid of it because the kids were scared to use this 16" wide beauty. Tell us more Keith.
In the first shot, down in the bottom left, you can see the corner of a PM 72 TS.
Then behind the wood stove, is a workbench, then a Unisaw with Unifence, and 42" x 96" out feed table. Behind that is a edge sander, then a junk room.
Off the end of that out feed table is where I would normally set up this Hot-box, but my helper and another friend have a project filling that space.
Behind that, you can see my veneer storage drawers. It has 9 4' x 8' drawers in it.
Then on around clockwise, is an Oakley double belt stroke sander, with a 5 hp, and 7.5 hp motors. I have 11' of length capacity between the wheels, and the platen is on an arm with 3.5 ratio of leverage going to the platen. It came from a church pew plant, and had two tables end to end when I got it. But I didn't want to have to buy belts that long. Now they are 30' long, so it hurts when one breaks prematurely.
Next to that, is a PM Chain Mortiser then PM Tenoner. Those are behind that dust hood in the second shot, which is on an old 24" Crescent planer, with 15 hp
The Jointer is Hall & Brown No1, 12" with 5 hp.
There is an old Delta shaper behind the post, with a 12" lunchbox Delta planer sitting on it.
Back against the wall, is a 16" Radial saw with 5hp, and 30" travel. and 12' of table on each side.
On to the right, is my sailboat, in a bay. It is a S2 7.9
Then there is another Lobo 18' bandsaw.
Then my big Bowl Lathe, in it's former life, it was in an old Railroad shop, set up for grinding the wheels. It has a 4.5" diameter arbor, with two rows of tapered roller bearings on each end. Powered with a 5 hp Panasonic motor, and VF drive
Then another PM Lathe, couple of drill presses, then grinding station.
Oops, back over to the big band-saw. It is a 36" Defiance, with patent dates of 1904 - 5. I've had it about 25 years. It had a crude wooden table, which was made in the shop where I got it. The old shop burned before it was salvaged there. It had a 5 hp motor on it when I got it, which I lived with about 10 years, before putting a 7.5 on it. It is a high-speed, so the blade travels over 60 mph, and has 14" under the guide max.
Next to that is a double spindle shaper that I built about 30 years ago, using the base from a tire balancing machine, old 5 hp motor, and spindles bought from Memphis Machine.
Outside, is the Woodmizer LT 15, Tractor, Box trailer, Car-hauler and Toyota truck.
So I guess you could say, I have a pretty well equipped shop, in this old Safeway #10, built in 1926-7, about 5000 sqft. and 12.5 ceiling height. It already had 600 amp 3 ph service when I got it in 1983.
That is probably more than you wanted to hear, so once again, I think the lesson is be careful what you ask for. he he.
A cardinal rule for operating a kiln is to have uniform air circulation throughout the pile- no dead spots and no hot spots. If I understand this arrangement the hot air blows on the end of the stack. A key point in the success of this method is that the lumber being dried is quite dry to begin with. At some initial moisture content and with some difficult to dry species like oak the board ends receiving this blast of what must be very hot air will check, and maybe severely so.
I won't argue with success but if I was to implement this concept I would look for some way to distribute the hot air across the edge and then through the pile.
We used to use a large scale version of this technique. We would pile up about 2000 bdft of some easily dried species, for example poplar or cherry, that was already air dried. Then we would build a crude covering around it from the cheap black insulation board. Fans would be placed along the side of the pile. A large fuel oil burning heater(I forget their name, but contractors use them) would be placed at a corner and its blast directed along the side of the pile where the fans were located. I think the heater was 300,000 BTU but I may not be remembering correctly. The sum of the side fans and heater fan created a lot of air stirring throughout the pile. We only ran the heater half time (days), which allowed the moisture withinin the lumber to equilibrate during its resting period. Poplar would dry from air dried to 5-7% MC is 3-4 days. I never risked drying oak with this arrangement.
Bill, I don't disagree with your concern, but this is not intended to be instructions on how to build and run a commercial kiln.
I think I recall a little while back that you had some insects in your stash. Ants if I recall correctly, which was lucky for you. If it had been PPB, then I'd like to hear your remedy. That was what Ellis ask for in his Ides for January.
I was finishing off R Oak in the run above, and didn't have a single end check. I probably would have, if the MC were higher. And of course, I believe end coating helps reduce that.
Also, If you didn't catch it, the little heater shown, has an oscillating base, so it does a pretty good job of mixing up the air inside this small space. I should have mentioned, that I usually make the opposite end skirt a little shorter, so most of the heat escapes on the far end.
When I want to do a larger run, I have a floor frame, with ~ 18" legs, then I send the heat under, and do put a fan on top, with provisions to send the heat back down the opposite end to the bottom. My stack of insulation foam lives in a loft until I need it.
If the goal is to kill the bugs with heat, I don't know about turning off the heat at night with this little heater. You'll have to do that test and post your results.
You may be able to get the temperature high enough in an hour with that 300,000 BTU heater, if it doesn't blow the tarp off, or burn it down. he he
Ive done something similar using blue board insulation...stuff they slap onto homes outsides before residing...probably halfor 3/8th, probably 2ft high by 6ft long by 20 or so wide...cut hole in end for heater....temps into 160s...used on air dried or shop stored lumber when making a project. Just put together with that rube goldberg favorite . Duck tape.
I understood that the post was about bug killing. But, if the moisture content of the wood is high, drying will be occurring during bug killing. My caution is that too quick drying of difficult to dry species will result in problems- honey comb, case hardening, and/or checking. You seem to understand this potential problem and avoid it. Someone inexperienced may in their zeal to sterilize lumber might put oak in this environment at 25% MC and destroy it.
I did send Ellis a follow up, that I had been contemplating working my steam pot, which is a 5 gallon canning pressure cooker, that I tapped out the blow-out hole for a hose barb. then added a auto heater hose, into the equation mainly thinking of conditioning the wood at the end. But I have not done that yet, and don't know about trying to keep that on over a long period, so didn't go there.
Well, as far as I'm concerned, If they were in there early on in the drying, they might get culled anyway. There may be some custom kilns around, but I've not sought them out to see what is available.
I really don't saw much lumber that is susceptible, and even saw the sapwood off most of my Walnut Cherry and W Oak, just to not have that worry. Keep in mind, that my milll is for my personal use, and most of my trees are urban, and given to me by friends or friends of friends who hate to see their trees go to waste, and which are larger than the average sawlog.
