correct router w/top adjustment capabilities
Garrett Aston
I purchased the cast iron router table extension from Grizzly for my table saw. And wished now that I had researched table add ons. This has the round hole which I believe limits my ability to get the adjustments needed.can you offer suggestions for router or set ups .
Re: correct router w/top adjustment capabilities
My recommendations are as follows. Others may have completely different opinions, but these work for me:
1) I don't buy anything from Grizzly.
2) Table Saw fences have completely different requirements from router fences. These include dust collection, location, accessory attachment, stops, guard configuration, miter slot location, etc.
3) On many milling operations, the table saw function and the router function get in each other's way. I often need to run a molding on the router table and then rip it off on the table saw and then run a molding again. The need to move the fence and retract the router bit results in wasted time and, more important, serious inaccuracies. Therefore, the router table should be completely separate from the table saw.
4) Look seriously at a Jess-Em lift and router table top. Cast iron is not necessary. Their phenolic tops are flat enough and durable enough, and they don't rust.
Hoa in Alameda
If you'd like meaningful replies, please provide more details.
1. What model of the Grizzly table extension is in question?
2. What is/are the limit(s) are you facing?
3. What is the make/model of the router you are using?
If this is model T10222, you may be able to use a Router Raizer to add above-table-adjustment capability.
My setup: Stamped-steel table saw extension with round opening + Hitachi M12V + Router Raizer + Incra fence (older model, similar to LS Positioner Standard). Works great.
