Tuesday Night Hand Tool Chat - Static Electricity
Stephen Shepherd
Stephen Shepherd
It is Tuesday once again and time to gather and discuss HAND TOOLS and related subjects, tonight's topic is static electricity in the home and workshop. Got any good ideas how to eliminate this shocking problem?
If you can help or would like to just lurk you can to so this evening at 9:30 o'clock PM Eastern Time and will run for one scheduled hour. Just click on CHAT ROOM on the left and join in.
All are welcome, hope to see you there. Where is Michael Faraday when you need him?
Stephen Shepherd
Host - Hand Tool Chat
Re: Tuesday Night Hand Tool Chat - Static Electricity
yes
move to a more damp climate. When I lived in MN and winter RH was nearly unmeasurably small making like Zeus and shooting out lightning bolts was an everyday occurrence. It is rarely an issue here in TN.
A fairly easy fix is to use a liquid clothes "softener". I worked in Industry prior to retiring, in some areas we assembled printed circuit boards. Static electricity could damage or destroy our products. We dipped the plastic storage bins in a solution of a"Downy" like product and water. We also mixed up a diluted solution and filled spray bottles, used to mist carpets, clothing and other materials. All the laundry softeners work in the same way, they are hygroscopic and draw water molecules to any surface where they are present. The water prevents the buildup of static electricity. Note that absolutely pure water is NOT conductive but always contains enough contaminates in normal conditions to be conductive. The "dipping" and spray mist treatments are not permanent and do require periodic re-treatment.
