Got my veneer today. Now what?
Joe in a Cleveland suburb
UPS came with my 1/16" poplar and cherry veneer today.
It was in a box. I opened the box and the veneers were rolled up wrapped in paper. I went to cut the paper so I could unroll it and the whole mess popped open and unrolled like a big spring. Because of where my hand was, partially holding it, it split the veneers right down the middle. Great.
I guess I can deal with the split, but I'm not sure how I'm going to cut this stuff on the ts. Neither the cherry or the poplar have a nice straight edge.
I suppose I could make of some kind of sled or something to get an initial straight edge. Suggestions?
I hope to get an hour or so thighs is weekend to do some ww'ing...
Thanks.
Re: Got my veneer today. Now what?
Jack Guzman from Maine
Straightedge and a sharp knife should do the trick. Make your first cut light to set the line then cut through the second time.---Jack
Keith Newton
TS sled is my favorite way to cut it. I have one which is 8' long. I normally just cut the whole stack at once.
You will need a really nice fine blade, and I use a 3/4" mdf platen with added weight on top to flatten the lumps and bumps, so having a infeed table will be needed to get it all ready to feed.
If you are book matching it (or otherwise matching it), you will need to cut a pair of straight edges. If you don't need to match the figure, then it is much simpler to glue it down first and trim it to size afterwards. However, if you are using a vacuum bag, that doesn't work, because the bag very unevenly crushes the overhanging edges.
There are lots of workable alternatives to the TS sled. I have laid down a stack of veneer sheets the I had cut close between two previously jointed boards, clamped down the whole sandwich and shot them with a #7 jointer plane. I've done the same with a DJ-20, but the problem with that method is holding the stack perpendicular to the cutter head, as the clamps and fence interfere. I have used a veneer saw* against a straight board. I have used a 1-1/2" wide paring chisel against a steel straightedge with PSA sandpaper stuck to the bottom. This last method can be problematical with gnarly burl veneer.
If you've never done veneer work before, practice on scrap is highly recommended.
*Most veneer saws are kits. They are not sharpened properly and they don't work at all if you are left handed.
Thanks guys. I'm not doing any book matching or anything fancy with it. I'm using it to wrap around my half circle form with 1/16" layers.
I guess I will try a sharp knife and straight edge to cut out my strips.
Thanks.
Ralph Lipeles
I learned veneering the old way. There is a tool called a veneer saw. It is basically a section of flat steel with a curved edge and saw teeth along the curve. There is a handle that is used to hold the the saw and drag it along the desired path. I put the veneer down on a piece of scrap plywood or Masonite. A straight edge is placed where the cut will go and the veneer saw is pulled along the straight edge. This approach reduces the possibility of the cut following the grain which can happen easily when using a knife.
Veneer saw vs a knife
Howard in Toronto
I've always gotten better results with a veneer saw. A knife really will follow the grain. For a straightedge either a metal yardstick or, if it's a shorter length, a piece of MDF will do.
Multiple light passes to make the cut - you want to separate the fibres, not wrench them apart.
If you're using a vacuum bag and will trim to final size afterward, avoid crushing the veneer by laying a board larger than the veneer and substrate you're gluing. The larger board on top of the veneer will let the entire process work just fine.
Howard
Re: Veneer saw vs a knife
Jesse Cloud
With 1/16 stock, a knife will wear you out before you get a sizeable number of plys cut. I would use the table saw method mentioned above.
You can break down the long strips with a regular handsaw if you make a stack with an mdf platen on top and clamp them down tightly.
When you are cutting thin veneer, find a rotary cutter for fabric - your wife may have one if she sews - they cut great and no sharpening needed.
Tracksaws work well for this, too. And if you have a Festool track saw, get the metal cutting blade. It will cut even very thin veneer perfectly with no need for cleanup.
Looking ahead, when you get all the plys glued up, you can do a rough trim on your bandsaw or table saw, then clean up on the jointer.
Thank you
Thanks much all!
I'll let you know how it goes.
Works good for crosscut also, but
Keith Newton
For both ways, you always want zero clearance on both sides of the blade underneath, to prevent any chance if flutter, which would cause splintering. Of course that would just be a scrap of 1/4" mdf, if your sleds are old like mine, and been used with daddo or tilted blade.
Re: Unifence
An advantage of the Delta Unifence over typical Beisemeyer design fences is that the fence can be lifted above the table top and locked in place, the glued-on veneer overhang the edge of the substrate slid under the fence and the veneer and substrate trimmed to size all the way around. But, Delta no longer makes them, and mine is long gone, sold with my contractor's saw when I upgraded to a SawStop. :^( Of course, everything else about the SawStop pleases me no end.
Thanks for the great tip on the Festool tracksaw metal cutting blade. Off the top of my head, I can't remember why I needed to buy that blade, but now I have another good use for it.
