Fireplace Paint
Fireplace Paint
Fireplace Paint
I have a new wood burning fireplace. The inside of the firebox is new brick and mortar. I would like to paint it flat black, to match the surround. Have you used a high temperature paint for this application that you can recommend? How much will I need to cover the two sides and back? The firebox is 2' high by 3' wide by about 2' deep.
Re: Fireplace Paint
Re: Fireplace Paint
I used Rustoleum flat black "barbeque" paint, supposedly good to 1000°F, on our fireplace door set that seals the firebox. It has held up for 15 years however the surface is not directly touched by flame.
Re: Fireplace Paint
Re: Fireplace Paint
Robert Fuller
Willing to bet the paint, even the high temp stuff, will not last long. If it does not, get a container of carbon black or lamp black and rub it into the brick and mortar.
Re: Fireplace Paint
Re: Fireplace Paint
I looked at the Rustoleum, and while in general I like Rustoleum products, it is described for metal, but not for brick and mortar. Where I am using it, it will definitely be exposed directly to flame, smoke, ash and logs. So far, I'm reluctant.
Re: Fireplace Paint
Re: Fireplace Paint
If I could find out what was used in our other fireplace, I would like to use something similar. It has held up for many years, both on the brick and on the metal plate that is behind the fire, but that one also now needs another coat of finish. There's lots of lighter colored smoke and ash built up over the years (but insignificant chipping or peeling) that I would like to cover up. Carbon black I have (I use it for coloring epoxy), but I think it is the binder that is critical in this application.
Re: Fireplace Paint
In The Firebox
You'll need "kiln wash" which is kaolin clay to which you can add your carbon black. You'll have to renew it from time to time but dem's da breaks. ;)
ps: Get it at a ceramics supply.
Re: Fireplace Paint
Re: Fireplace Paint
Howard Acheson
Here is a source of fireplace paint that came up using google. They seem to have a number of choices.
http://www.efireplacestore.com/cpf-43400.html
Re: Fireplace Paint
Re: Fireplace Paint
I did the same sort of search with Amazon. But there were not enough reviews from people with experience in my particular application to be sure of choosing the right product, and not enough information on the cans. At my local ACE Hardware, I bought a small can that I can brush on, I dug a brick out of the snow out by the shop, and brought it in to let it warm up. I'll paint it this afternoon, let it dry, and place it in a corner of the fireplace for a few days to see how the paint holds up under real world conditions. I'll report back here when I have decided whether or not to do the whole fireplace. If it doesn't work, I'm only out $14. If it does work, I suspect one pint won't cover two fireplaces, so I may have to go back for more.
