Have a question? Ask Woody!
Center
Center
Center
Gary Smyth
I have several old 4" hollow brass balls that have a hole in them at one point. The existing holes vary from 1/4" to 5/8". I need to drill at least one additional 5/8" hole, centered exactly opposite the existing opening. I can not consistently find the opposite location to drill. I have experimented with tape /paper strip wrapped and measured around the circumference, - eyeballed a plum bob along side the sphere - set up a "L" shaped gauge on a sturdy stand to locate the highest point on the sphere opposite of hole surface. I keep getting different locations -- sometimes as much as 1/4" out. The balls will be "strung" on a round 5/8" rod, and when viewing them they must appear to be stacked in line, on top of one another, one shot to get it right with no visual variation or off center "wobble". I'm looking for the centering no more than a 64th off center. This can not be as difficult as I'm making it. Once the center point is found, a centering punch dimple and drill press drill will step up to make the hole. Where am I producing the variation?
Re: Center
Re: Center
Mark Hennebury
It seems to me that you could set up a fence on the drill press; the fence would have to be a least 2" high and 2 " from the center of the drill and have a side fence also 2" from the drill center. When you lower the drill into the hole and down to the bottom it would be at the dead opposite position to drill through and make the second hole.
Re: Center
Re: Center
Gary Smyth
I'll check that. The drill will have to match the hole size to reduce the possibility of drift/going in off center. Nice sketchup. Thanks.
Re: Center
What is the wall thickness?
Keith Newton
If your balls are thin wall, you first obstacle is enlarging the smaller holes. A normal twist drill may try to screw itself up the flutes, as the tip punches through the front small hole. I would start with a stepped drill, if it is thin. This is what they are made for, they have straight flutes with no spiral.
Once you have a front 5/8" hole in all of them, you can do as Mark described, or you can clamp a piece of mdf on the drill press table. Then use your largest drill to bore down into it. This will establish a pocket centered under your chuck, so setting a ball into this pocket should self center, when the bit comes down through the hole on the top side. Here again, a high spiral bit in thin material is not your friend, because of it wanting to climb the flutes as it punches through.
You can remedy this by grinding a 0º hook on the face of the cutting edge of the bit. This is not that hard to do, if you have a good eye, just using the corner of your grinding wheel, cutting with the side. I have a dish side fine diamond, which makes this easy, but your can use any normal grinding wheel.
Of course, if you don't trust your sharpening, you can order slow spiral, or straight flute bits which are made for this reason.
Re: Center
Re: What is the wall thickness?
AlanWS
To expand on a method for thin wall brass, if you use a common stepped bit, you can't come through from the opposite side as shown in Mark Hennebury's drawing above. A slight modification that would allow a stepped bit would be to drill a hole in the base of the jig, and insert a short dowel. Putting a ball the other way up over the dowel, and holding the ball to the fences, would allow a stepped bit to drill in the correct position.
Re: Center
How to find the Center
Lee Schierer in McKean, PA
To find the exact center point on the opposite side of the ball, use Mark's design with a couple of modifications. First measure the diameter of the ball and the diameter of the existing hole. Then build the two walls of the jig the exact height of the diameter. Then measure out using half the diameter, perpendicular to each wall and make a center point for a hole in the base. Drill a hole and add a short length of dowel that matches the hole diameter in the ball. Place the existing hole over the dowel. Now take your combination square and align the blade with the corner of the two walls exactly so the edge of the scale is aligned with the corner notch and the blade extends out over the captured ball. Mark the top of the ball with a pencil. Now rotate the ball about 30 degrees and make a second mark. Rotate once more, mark and you should have the exact center on the opposite side.
Lee
Re: Center
What I would do...
Grant in Iowa
Gary,
Since you already have one hole in each brass ball, begin drilling from that side. Here's how I would do it:
Using a 2 1/2" or so hole saw, drill a hole in a piece of plywood that is clamped down to a drill press table. Remove the hole saw bit and the plug without removing the plywood or moving the drill press table. You now have a jig to hold the ball centered.
You can now place the ball to be drilled in this depression and it should be nicely centered. Install the bit for the hole to be drilled in the DP, and drill through the existing hole to ensure they will be across from one another.
My approach won't yield machinist level accuracy, but it should be close enough for bed knobs or other woodwork.
I am not entirely sure how to secure the work piece, but I would try a strap wrench or maybe hot melt glue to secure it to the board with a hole in it.
Regards,
Grant in Iowa
Re: Center
Re: Center
This is how I would do it: Start with a block of hardwood, precisely square it and thickness it. Cut two v-shaped slots precisely through the center of the top perpendicular to each other. This is relatively easy to do on the table saw. Note that your ball will sit precisely in the intersection of these two channels. Take the block to the drill press, and install the smallest drill you have in your chuck. Align the drill bit with the intersection of the v-channels and clamp the block down. Replace the small drill bit with the 5/8" bit and drill a hole in the block. Drop in a short 5/8" diameter dowel. Drop the ball onto the dowel. Replace the 5/8" diameter bit with whatever size bit you want for the hole. Drill the hole.
Re: Center
Wall thickness .081 - 12 gauge
Re: Center
Re: Center
Tony - Memphis
I would think if you built a box with inner dimensions the same as the diameter with a pin the same diameter as the original hole, that the ball would have to be oriented such that the axis of the hole would be vertical. You could then use a center drill (anything with a point) to locate the ball under the drill chuck correctly. I'm guessing this could get you pretty close. You could also use the end of an indicator to mark the ball top at its center point.
Lots of good ideas here. Let us know how it turns out!
Tony
Re: Center
Combination of suggestions
Gary Smyth
will get me there. Tried only a test (I still have to drill) but glued up a right angle "wall" to reduce the freedom of the ball. Set the ball on a 3/4" cabinet grade plywood flat surface with the two walls "holding" two sides of the ball. The ball is resting on its "bottom" where the hole is and is relatively stable just resting on the hole opening - made more so by sliding it tightly to the right angled wall.
The ball and right angle frame is set on a drill press table previously leveled using a round what I call a target level.
In the drill press I chucked a hardened machinist pointed scribe. It may or may not be perfectly perpendicular to the drill press table, but close -- besides, it is only the point of the scribe I want to use. Using the drill press quill lock I lowered the quill just shy of the top of the ball sphere. By using the threaded portion of the quill stop I unlocked the quill and minutely lowered the scribe until it barely, barely touches the only place it touches the ball. In a sphere, that has to be the top. When the top of the softer metal brass ball gets a small scratch the quill is locked. Using that reference mark the ball tray is slid away, the ball is rotated, and slid under the scribe again. A scratch is made. If the ball is not a perfect sphere the scribe can be raised or lowered using the quill lock screw until it again barely touches the ball. Since the sphere has only one top point when it is restricted on three surfaces, the scratch should be crossing or very close to the first scratch. The process is repeated until I feel comfortable that the scratches provide me information enough to confidently dimple a point to start a pilot hole. Wire and standard drills will gradually approach the finished size. A drill press chucked machinist taper reamer will finish the hole. This is a bit time consuming because there are multiple balls and they all rest differently requiring multiple adjustments. But, so far, the center scratches are very very close.
I also measured the 5/8" rod they are to slide on to. It is not a perfect 5/8" diameter throughout its length. As such there will be some + in the hole size of the balls. When the balls are placed on the rod the slight difference will (I trust) not be visible.
I still have to do the work and after mocking up the "look" I'm thinking about a design change to perhaps graduated size OD of the balls. I don't have graduated sizes (yet), but maybe.
Thanks to all.
