Samantha's dresser8- Installing the facing
Adding the facing 8
For rustic/country/ primitive style I would leave the dovetails exposed. But I want a more formal look to this piece so they will be covered up. Back a few steps there was step I did not describe. An 1/8” thick strip was sawed from what would become the front side of the board used to make the side panel. This strip was sawed off when this board was 1/16” thicker than the side thickness, leaving it 1/16” wider than the final case side thickness. This strip would become the facing to cover the dovetails. Grain match on the side between this facing strip and case side will therefore be well matched.
Note: The edges of wide boards are usually rift grain so grain matching is typically easy.
I use a 40T- 7 ½” very thin kerf Industrial quality blade for this operation. Well, in fact, I use the blade almost exclusively for woodworking, but we have discussed that all before. The goal is to be able to glue it back on and have the grain match on the side. With care one can get a “glue joint” rip with this blade, or at worse a tiny amount of sanding/planing will be required to get an “invisible” joint.
PIC1
There is a trick to installing this strip on the case side. It was sized to overhang the case side just 1/32” , to be trimmed after it was installed. Any slip during gluing it on can lead to disaster. To prevent it from skidding during installation, first drive a few fine gauge brads down the side and clip the heads off, leaving them sticking up 1/16”. The facing strip is then positioned to align the grain on the side as well as the overhang on the edge and given a bash with a hammer to set the brads into the strip. One now has indexing holes in the strip to reposition the strip on the case side after the glue is applied. It can’t skid when clamped.
PIC 2
PIC 3
The horizontal facing is cut from straight grained wood so as to not detract from the figured drawer fronts. The idea is to frame the drawers. These facing strips must be accurately fit and it is trivial to do so. Ideally they should be just a tiny bit long so that when captured between the vertical facing strips they will bow up slightly before gluing, as shown in the picture. How to make them such an accurate length? With a fine tooth hand saw, saw them about 1/16” too long and trim to length on a shooting board. Given that a few thousandths of an inch per pass can be taken off the ends with the plane the fit can be accurate.
PIC4
Note: If the front edge profile is other than flat, “darts” will be required at the intersection of the horizontal and vertical facing strips.
PIC5
In days past I would then sand and scrape the facing strips to smooth them and get them to align at the intersections. The inevitable grain reversals made planing them too risky for me. No longer the case. With the plane cap iron set very close to the edge of the blade tip there is no risk of tear-out no matter how the grain is running. (See Article by Weaver in Articles Section of WoodCentral on setting up the cap iron, or stay tuned for the next edition of Popular Woodworking). I still can’t manage a large plane teetering on a board edge and keep it under control. However, this more narrow block plane is easier to keep flat on the edge to be planed.
Note: When I made this plane I made the mouth tight as directed by David Finck. With the mouth tight, an ineffective means of avoiding grain tear-out in my hands, the cap iron can not be set close or the shavings jam. With the “rediscovery” of the cap iron effect, and the encouragement of “Kees” and Weaver, I said screw it and opened up the mouth to enable the cap iron to be set close. Works great.
