Samantha's dresser 7- case assembly
Assembly of the case
PIC1
The picture shows some of the 30 pieces that must be fit together to make the case. An initial dry fit of them all ensures that when the glue is applied the case will assemble stress-free. Some are successful gluing up case work in subassemblies first. I am not. To ensure the final case winds up square I like it all to go together at one time.
I use liquid hide glue for things that slide together. This glue lubricates the joint enabling the joint to slide together in a controlled manner. This glue also has a long working time. With the case sides on edge on the bench I install all the dividers on the back side- top divider, bottom divider and then fill in the rest. If you don’t have a helper a clamp like what was used to hold the boards to the bench for dovetail sawing (wooden hand screw) works just dandy for holding the sides upright on the bench. Then flip the case, add the runners and then install the dividers on the front side. At this point err on not having the dividers pressed in far enough for they are not easily retracted. The problem of proud dividers is easily cured later (see below). Then I set the case upright and inspect that the dividers are flush with the front and back side. If they are proud a bit, and some usually are, I squish them into position with a clamp across the case side. Finally the false top is installed.
It may be of interest here to describe the two “glue times” that are relevant to this assembly. “Open time” is the maximum amount of time the glue applied to the open joint can be exposed to air before its surface hardens and interferes with proper bonding. This time depends on temperature and humidity as well as glue type. “Closed time” is the time after the joint is assembled that the joint can be coaxed into position. This time depends on glue type, temperature and moisture content of the wood. This time is typically longer than open time. Fifteen minutes is a typical closed time.
The glues we use have low shear strength before curing. Coaxing a joint into position is best done with steady clamp pressure. Bashing is futile once the bond begins to cure, while clamp coaxing usually saves the day.
Using the construction described, namely dovetailed dividers and a dovetailed top, there is nothing to clamp. However it goes together is how it will be. If the dovetails on the ends of the dividers were square the case must be square. The handy jig shown previously ensures this is the case. After assembly I measured the diagonals and they were within 1/32”. I was pleased. Square makes drawer fitting a breeze.
Note, it sits on a platform with casters. I find this arrangement handy for working on it. I can easily wheel it to whatever position required, or out of the way.
Also note the dovetails are now covered up. The next installment will cover that operation. The lumber sticking out of the drawer openings are drawer parts. It is handy place to store parts.
