Drill Chuck Question Follow up
Three days ago I posted a question about how t tighten the chuck on a little Bosch L-ion drill. I was a little embarrassed to discover that choking the chuck in one hand and spinning the motor with the other on the switch might not be the best way to do it and that you can tighten it better by hand. Apparently the shaft locks when the drill stops and you can really cinch down on it even when the clutch is set to one of the low settings. Originally, I thought the problem was that the drill stops so suddenly that it was impacting the chuck loose.
Well, yesterday I was using it again to drill a few hoes for my Kreg Jig and then drive the screws. I put the bit in the chuck and spun it home and then cinched it by hand. In the process of drilling about ten holes it came loose. I put a hex shank square drive bit in it and drove the screws. Again, tightening the bit as tight and I could. Somewhere in the process of gently drive the screws, the bit fell out and I was not running the drill any where near full speed.
I think I need a different Chuck. I have not heard from Bosch.
