A55 Smoothing Plane
Bandsaw insert for Steel City bandsaw
Johanna Johanson
Does anyone know if the zero clearance inserts for Jet or Powermatic will fit a Steel City bandsaw? The outer diameter of the top is 2 1/2". The diameter of the lip is 1 3/4".
Re: Bandsaw insert for Steel City bandsaw
I make them
I have a Steel City 20" bandsaw and I've always turned my own throat plates for it. It's pretty tricky to make a zero clearance plate, though, as the only good way to figure out where the slot goes is to measure from the sides of the opening and then transfer those measurements to the new throat plate. Even then, you might have to tweak it a bit.
Ellis Walentine, Host
Re: I make them
Tom in Toronto
The insert for my Laguna broke, so I was going to make a new one, and that was about 10 years ago. So probably a bad idea not to have one, and I am sure there are veneer sawing applications that an insert might be essential for. Sure cuts back on those little pieces that get jammed in the blade, which I guess the zero clearance insert would also. They sell blank plastic inserts you can cut, or turn or saw, just in case you live in a world without any materials you could make one out of.
Maybe the solution to the zero clearance issue, which I also have with making mine, is to cut the slot first, then scribe the pattern from the underside of the table. Or another approach is to make a perfect fitting insert with a big hole in it, then get some extra scraps and paste those in tight. Then use that conglomerate as a perfect pattern for an actual insert.
Ellis, how do you like your saw, is it the one with granite tables and wheels. Are they still in business.
My saw is an older one
Steel City is still in business, but they are dealing mostly in smaller machinery these days, including the granite-table machines such as bandsaws and tablesaws. I've been reasonably happy with my older 20" bandsaw, but not ecstatic. The blade guides in particular have been a source of problems -- cheap bearings, fiddly thumbscrews that don't hold their setting. Other than that, the 12" resaw capacity is pretty small for a saw this size. There's no question that it is a price-point machine, but it has served me well.
Re: My saw is an older one
Tom in Toronto
My Laguna is also weird, for one thing, it doesn't have their logo on it, which will hurt if I ever sell it. And it was a special upgrade model with a set of Carter guides that are all but impossible to adjust because of the ham fisted way the guides were attached. But it works well enough also.
