Samantha's dresser 6- drawer runners
Drawer runners
PIC 1
My drawer philosophy is soft drawer sides and hard runners. Drawer sides are easily repaired when worn, while runners are not. The picture shows the piece being dry fit together. I find a dry fit organizes the parts for trouble free glue up. And, it ensures everything fits. I don’t want to discover a problem in the midst of glue up. Runners are designed to be just a tiny amount (1/64” approx.) proud/taller of the dividers. Erring on this plus side avoids the bad situation of a runner being below the divider. The runner tenons should fit loosely in the divider mortises. If they fit tight assembly of the case will be stressful (been there and done that).
Over the years I have had some trouble getting the height of the runners just right. I find the best way to fit them is to center the mortise in the divider and center the tenon in the runner. Additionally I make the runner a tiny bit thicker than the dividers so that they will sit above the divider a tiny amount, or at least be flush.
PIC 2
I use a tenoning jig to cut a tenon on the ends of the maple runners. The runner must be backed up with a scrap or the back can blow out when the dado blade exits. I ensure the tenon is centered by cutting one side and then flipping the tenon to cut the other. I hand plane the bearing surface of the runner to be glass smooth. It will be waxed later.
Acknowledgement - In making this piece, and writing about it, I realized that much of what I am describing is what I learned working in the Mack Headley and Sons shop under the guidance of Jeff Hadley and Steve Hamilton. (Website WWOTSV.com) If you find yourself struggling up the learning curve of furniture construction take a class with these people. The class on the French Footed Federal Wall cabinet is an especially good class in that it involves case assembly, a drawer, a door, veneering and French Footing. And you will wind up with a $1400 cabinet to put your CD’s and books in.
Re: Samantha's dresser 6- drawer runners
Jack Guzman from Maine
Bill,
That's an interesting looking tenoning jig. What make is it? age?My Grizzly is a flimsy piece of junk next to it.---Jack
Re: Delta jig bought about 1980
I have a delta jig I bought about 15 years ago for $100 that does not appear to be as beefy as Bills, but it is quite substantial.
Question
Will you Shellac the runners before you wax them?
I used QSWO for runners. Trying t decide on wax or shellac first.
I don' t use shellac or oak for runners
A theoretical analysis of the situation would lead one to conclude that a porous wood that might trap abrasive dust in its pores would not be the best choice. I have lots of hard maple so that is what I use.
Again in theory....Shellac would soon wear off the sliding surfaces of the runner/drawer bottom so no advantage of putting it there to begin with.
I do shellac the drawer sides and case sides. It will make each much more stable (not theory, I am collecting data on moisture transport as we speak). I was amazed how much a finish slowed down moisture loss (and probablfy gain but I don't have that data yet).
Re: I don' t use shellac or oak for runners
Good thinking, I think.
I have lots of QSWO and those rays are about as hard as steel. So I used it because it is hard and plentiful. We will see. Wish I had some hard maple. Not plentiful around here.
I think there is some gum down in the pile. Don't know which gum, I noticed the smell when it was freshly cut. Would that be a better choice than oak?
I guess I will be finishing the inside of the case with shellac. Trying to use shellac on the interior to avoid the smell of the lacquer.
Question - 2
David Yoho
Bill, in the first photo I can see some type of stands you have the case sides resting on. They don't appear to be actual saw horses but I can't see enough to tell what they actually look like. Can you talk about them and maybe provide a photo.
I do almost all of my assembly as well as everything else on the free-standing bench at the back of my tablesaw, which also acts as an outfeed table. I wish I had the space for an assembly table. Once in a while I will bring in a couple of saw horses for the odd times I need the extra horizontal space but they have a footprint that makes moving around cumbersome.
David Yoho
Barry, everyone's got their way of lubricating wood-on-wood drawers and runners. Sometimes I just apply Johnson's Wax but if it's a dresser or something with larger drawers I use what Suter's Furniture does - parafin wax. I have some leftover tea light candles (not the ones in the metal cup) we used years ago in white paper bags to line our sidewalk one evening. I've found them easy to rub over the mating parts to allow for easy movement of the drawers. That QSWO should hold up well with just wax for lubrication.
they are "Krenov saw horses"
I saw these in David Finck's (the plane person) shop. It was love at first sight. I went straight home and made some. I have never acted on shop furniture so fast.
Recommendation: I thought them frail(wrong) so I made the first pair from 5/4 oak. Bad idea. The wonder of these things is that you can hook a pair under one arm and carry, or position, them one handed...... provide they are not too heavy. I promptly made a second pair from 4/4 oak. Much better and they will hold anything you would ever need to assemble.
Thank you.
charlie belden
A tenon jig that can't tilt? How retro!
Nice work.
