Bandsaw Blade Drift
Don Emmerling
Hi Folks,
I have a Jet 18" bandsaw and I was trying to resaw a piece of 1" walnut to 3/8" for another project. The board was about 6 or so inched in width. I used a marking gauge to scribe the line to follow on the saw. I started out using the fence to guide the cut but realized about halfway through that I was getting a bit of drift and could not stay on the line. I moved the fence out of the way and continued to cut to the line by slightly angling the board. I was cutting very slow with just a gentle push to run the board through the saw. I believe the bandsaw blade is a bit dull but at least on other cuts it seems to do well. After sawing the board through I noticed that despite staying on the line at the top the bottom part of the cut had drifted so that I essentially was cutting on a diagonal. While at the top of the board it was 3/8" and at the bottom it was more like 1/4". I have had this happen before on resawing efforts. The blade tension seems good. I also noted that the diagonal like cut seemed to start approximately halfway through the resaw, coincidentally or not when I started to cut freehand, that is without the fence. I am not quite sure what is causing this. I see youtube videos of resawing and they always just seem to buzz right through the effort and everything is square. Any thoughts out there in woodland?
