dado throat plate
shawn
I have a craftsman 315228380 older tablesaw and purchased a dado/molder throat plate for it. I also just purchased a 6 inch pro dado set.Problem is throat plate says use only 8 inch dado or molder only.Will a 6 inch work?
dado throat plate
shawn
Re: dado throat plate
David Yoho
A six inch diameter set being smaller will work fine. You just don't want to go larger than the eight.
Just be aware...
... that a throat plate with an opening large enough for an 8" dado cutter will have a lot of extra room fore and aft of a 6" cutter set for the same height (i.e., cutting depth) as an 8" cutter. This could be an issue if you're dadoing or molding short or narrow pieces that can tilt into the openings around the cutterhead.
Also, when using a dado throatplate, be wary of the excess opening to the side of your cutterhead. Narrow dado heads leave proportionally larger spaces on the arbor-nut side of the opening.
Analogous cautions are in order for router table openings.
Ellis Walentine, Host
Follow up/addendum
Rod Peterson—Ormond Beach, FL
Ellis' points are extremely well taken. I would add that, due to my intimate knowledge of The New Yankee Workshop and the techniques and practices therein, I observed that Norm used more than one dado insert during the course of the series.
His first and ultimately, his go-to insert for wide dados, was the original insert that was available with the Rockwell Unisaw he used. It would accommodate a full width (usually around 13/16") dado set. He never replaced that insert, even when the new Unisaw appeared around 1994.
In later years, when he was doing a lot of groove cutting in frame-and-panel work, he would typically use a ¼" dado setup and had a dedicated melamine-like insert with only a ¼" wide opening which he used with it.
In addition to the remarks about the differences in the amount of open space when using a 6" dado set with an 8" insert, any dado set raised to take a shallow cut will leave more open space than when it is raised to take a deeper cut. Caution all around is warranted.
What I did was to make a bunch of inserts out of Baltic birch Plywood scraps. I had about eight. Left them blank and then raised whatever setup of blades I was using through them when the time came. Thus, Zero Clearance inserts. I saved them for later in case I used a similar set up. They get chewed up over the years, but they are cheap and easy to replace. You can pattern route them or just cut them out with a bandsaw or jig saw and sand the to fit. They don't have to be perfect, just have enough slumps and bumps to keep them snug. Had to add little stabs of veneer to get the height right. Use a stick or block to hold them down while raising the blade to avoid your fingers. Incidentally, I had to use a single eight inch blade to cut the opening in mine for my Ten inch blade, it woud not retract far enough.
Bart Goldberg
I agree with Barry - use the throat plate you purchased as a pattern for making your own, zero clearance plates. You will get cleaner cuts, and safer cuts as well.
Bart
shawn
Thanks for the input.
I did the same thing Barry, I just roughed them out on my BS then used a pattern bit on my router to finish size. I also added Formica to the top side (I thought about putting it on both sides, didn't but haven's seen any warp yet) - still have 5 or 6 left after 5 years. I drilled, tapped the inserts and installed leveling screws (and a side screw to take out all the side play. I set them all level and tight on my Unisaw. I leave them "blank" until needed. I did install a 8" dado head on the saw (full width) and after setting my fence over the insert blank, raised the dado until the inserts were undercut enough to allow a 10" blade to be installed without rubbing. I also use the splitters from Micro Jig, so install them on the blank when using a standard blade. I think I spent about 6~8 hours making about 10 inserts.
