It will work, if...
John in NM
1. Your cauls are sized for the radius of the inner form + total lamination thickness.
2. Your cauls are sections rather than a full semi-circle.
3. You use thinner wood. Last time I did much of this I bought 1/16" cherry veneer from Certainly Wood, it will bend that tight, 1/8" probably won't. I did the inside lams with poplar and only the visible faces with cherry (said company carries both in that thickness).
4. You have enough F-style clamps. The jobs I did were curved top door frames for a paying client, so I ended up with 10 new Wetzlers (that should tell you how long ago this was
- 12 years). One clamp per caul was all I used, but if the cauls are wide or the clamps light, you may need more per caul.
I used Weldwood plastic resin glue, applied to both faces with a foam roller of appropriate width - roller is just the ticket for speed and even application. Zero springback on a 36" diameter semi-circle. Jesse gets great results from Tightbond as well, so I would use whatever is easiest to get.
I remember Ellis had some pictures of crazy curved glue ups, perhaps he'll post them again (those will give us all another bout of clamp envy
All that said, I also really like the block lay up method that William mentions above. I've had better luck cutting tenons on pieces made that way. Harder to get a tenon sized just so if it's laminated, one cheek cut always seem to fall on a glue line
Next time I make a laminated part that will need a tenon, I may size the mortise to it rather than it to the mortise. Or just block it up
