A55 Smoothing Plane
Drill chuck question
I bought a Bosch 12v rechargeable drill. The chuck did not work well. I put up with it. the drill got stolen along with the rest of my tools. I replaced the drill thinking they may have improved the chuck. Not. I put a bit in it and tighten it by holding the chuck and spinning the motor. As tight as I can. Drill about three holes and the bit falls out. I wrote to Bosch and they claimed they had Zero complaints in twelve years. They sent me a replacement drill. Its just as bad. I have been using electric drills for fifty years. I just lost another drill bit. It should be a nice little drill but as it is its a worthless piece of crap. Does anyone have any idea what I am doing wrong? How do you tighten a keyless chuck so that it stays tight?
Re: Drill chuck question
Keith Newton
I use the motor to run the chuck in or out quickly, but do the final tightening with the motor off, then I manage to get another quarter to half turn.
The only time I have had the bit fall out, I think may have been when I tightened down on the points of a hex shank, without noticing it.
Did you read the manual?
Dick Coers
You know, that book with all the safety warnings. Just picked a random drill and this is the instructions;
For small bits, open jaws enough to insert the bit up to the flutes. For large bits, insert the bit as far as it will go. Center the bit as you close the jaws by hand. This positions the bit properly, giving maximum contact between the chuck jaws and the bit shank.
To tighten, hold the chuck collar firmly with one hand and securely tighten the chuck sleeve with the other hand (Fig. 2).
Re: Did you read the manual?
You are right, I did not read the manual, at least not in living memory. I went on the site and tried to download the manual, but could not find it. I went to the shop and looked at the drill. The shuck is sort of "aerodynamically" designed and flows into the body of the drill. Right behind it is the collar you turn to set the clutch. I tried turning the chuck tighter with the drill off. sometimes the shaft seems to be locked and you can get a very small amount of tightening. Most times the shaft is not locked and you have to turn it backwards until it locks. Maybe a quarter turn but sometimes several complete turns. this was with the drill set to "drill" and not using the clutch. I just went a tried it again. It seems to work, if you tighten it enough to engage the shaft lock. Hopefully this is the answer and this old dog may have learned a new trick. What seems to have been happening is that the drill stops so suddenly that it "impacts" the chuck loose. Maybe that little extra turn will overcome that. Thanks.
Maybe your problem is you are buying Bosch drills? I have never had that problem with any of the De Walt or Festool drills I have owned or used. I always use the procedure you described: Strangle the chuck with one hand and pull the trigger with the other, for either opening or closing the chuck. Well, once it didn't work, but that was with a 3-1/4" Forstner bit. In that case I had to use my Millers Falls #97 breast drill instead. It has a crank, for a bit more torque on the chuck.
Note: in most every way, I prefer the Festools over the DeWalts, but the corrugations on the DeWalt chuck are the most comfortable for this operation of any I have used. A little 600 grit sandpaper helps my Festool a lot.
Joseph Mulherin, sr
Barry, look into the Rockwell 3rill. It drills, impacts good for drilling anchors, etc.
2yr warranty, 2 lifetime batterys included long with a 16 piece set of drill bits, screw bits too.
Re: Tools got manuals?????
I have the manuals for almost every power tool I have bought for twenty years. Can't remember reading any of them. Today I tried to find this one today and couldn't. I went on line to the Bosch and tried and tried but could not find the manuals to download.
I did try again to tighten the chuck and found that it locks and can be hand tightened. Sometimes you have to turn the shaft until it locks. I do not understand why this is more effective than using the motor to do it.
But men don't read manuals !
Jerry Nicholson
Yeah - in truth I have the manuals for most of my tools too, including my almost 50 year old Craftsman table saw. Now finding the manuals - that is sometimes a problem. I don't have the manual for my Cummins 1/4 inch drill with the original Jacobs keyless chuck. I assume it had a manual - I bought it new in 1948. The keyless chuck on that one is really pathetic. Drill a few holes and it takes a couple of pipe wrenches to get the chuck back open and the drill bit out. The old Cummins still works but I have a bunch of much new drills that work a lot better :b :b I have never had any kind of problem on my Makita cordless drills with keyless chucks.
Jerry
Didn't know they made deisel powered drills
Or ask for directions!!
