grinding wheel run-out
eliot feldman
For a smooth lathe spindle or the like, I would use one of those micrometer dial meters to check run-out as the spindle turns. But how do you do it for something abrasive -- e.g. a grinding wheel -- without ruining the tip of the micrometer?
Re: grinding wheel run-out
John in NM
They make dial mic tips with a little roller wheel. You also don't do it with the machine running, so you could probably measure a few turns of a grinder wheel without damaging the standard tip of the mic. I've never checked my grinder wheels, they seem to run pretty true so I don't really see much point.
Dick Coers
Fix a rigid point to the frame of the grinder. Rotate the wheel to the point you want to measure, slide in a feeler gauge. I never worry about measuring it, I just fix it. Are you measuring on the od, or the sides? I fix the od with a wheel diamond dresser, the side to side by adding paper shims between the washer and the wheel on the motor side, at the high point of the travel.
Tom in Toronto
It should just cut off when you true it particularly if you use a fixed cutter. And then the other thing is that you may need to balance the wheel more than true it.
With indicators the plunger can be retracted and then released on the surface being measured. So you can simply support it off the surface and rotate it to the next point and drop it down for a measurement. Same way one indicates in a square.
