Samantha's dresser5-dovetailing false top
Making the false top
PIC 1
The top of the chest of drawers has a top affixed with half blind dovetails. Its purpose is to hold the sides of the case flat, provide “kickers” for the drawer below and provide a means of attaching the overhanging finish top for the piece.
PIC 2
My bench was built many years ago in a time when I didn’t own a sharp chisel or plane blade. I am not inclined to build another to accommodate hand tool operations so I have learned to make do with what I have. The arrangement shown lacks the cool factor of a Moxom Dovetailing Vise but it works fine for the task of sawing dovetails in wide panels. Note I made something of a mistake in these tails (see below).
PIC 3
I have a history of problems marking the dovetail pins from the dovetail board. If alignment is off a fraction of a degree it throws the case or drawer off an unacceptable amount. If the tail board slips it is nearly impossible to get it realigned as it was. After a few slips and misalignments I have become obsessive about pin marking.
In the case at hand I dry fit the case to establish without question the orientation of all the parts involved. Then I clamped the tail board to the case to mark it. It is extra work but I find “crutches” make up for skill and experience.
PIC 4
The pin board is affixed to the bench, marked and sawed similar to the tail board. I show this picture to illustrate how well Pilot black ink shows up on walnut.
PIC 5
Tail waste is removed with a router, free hand. Klutz that I am I have no problem routing right up to the scribe line and saw kerf with arcing “nibble cuts”. Think of the router as a carving tool. Note I have good light and a router with ergonomic grips. In fact, I bought this router with it nice grips and internal LED light just for this kind of work. I use a solid carbide bit. They stay sharp much longer than the welded variety.
Others route this waste out perpendicular to the router orientation I use; I have no idea why. With the router in the position shown the base has a wide surface to ride on, rather than teetering on the edge of the pin board. What the router doesn’t remove is easily removed with a sharp chisel. I have never seen any need for a skewed chisel for this task.
Note the error of my tail marking. When a soft wood, in this case pine, is joined to a hard wood, it is more efficient to proportion the pins to tails so that the lesser amount of waste is removed from the harder wood. I should have reversed the size ratio of pins to tails.
