The return of real winter has plunged the shop humidity to a shop record low of 30%. It was no effort assembling the chest of drawers. What had been snug M&T joints fell together by gravitational attraction....no mallet required. I have never built in this low humidity.
There are various humidifying devices and approaches. What works most reliably?
I could just pore out some water on the concrete floor. If you have wood floors, you might wet something like a blanket or old bedspread, and hang it up near the heat source.
I have an ultrasound unit that I use in the studio, but it would never come close to keeping up out in the shop.
I have a two car garage that is electrically heated to around 12 deg C (say 55 F), half of which is my shop. If I'm not building anything, a car gets parked in the other side, usually covered in snow or slush and the humidity will fluctuate from 30% on really cold days to 60% on warm days.
The garage is pretty well insulated and not too leaky. When I try to control the humidity, which I only do when I'm building a guitar, I do a couple of things:
1) stop parking the car in the garage and keep the doors closed.
2) bring the humidity up using a dinky little Sunbeam room humidifier like you buy at any drug store. It might take a week or even two to get the humidity up to 45% where I like to keep it.
3) I have a large woodpile in the garage. I think this acts like a buffer because once I have the humidity up to where I want it, it's pretty easy to keep it there by turning the humidifier on and off as required. I might have to turn it on for half a day, then leave it off for several days and so on.
I brought the humidity up about to 45% a month ago, and for the past three weeks I have not had to use the humidifier; the room fluctuates between 40 and 45%. Outside temperature has ranged from -30 to +12 deg C during that period.
4) If the humidity gets too high (in the winter), I open the garage door for a minute to flush out some humidity.
5) If the outside humidity gets too high (in the summer), I keep the doors closed and I've found that the garage has not risen about 50% humidity inside. If it rises about that I will probably turn up the thermostat to drop the relative humidity.
I've observed that our shop at work, which does not get wet cars parked in it and does not have a humidifier, will drop to as low as 10% relative humidity at this time of year.
My house, which is pretty well sealed and has four people who like to shower a lot living it, but does not have a humidifier sits at 35 to 45% relative humidity year round.
