Edge cutting a thin sheet
Ralph Lipeles
I am making drawers for my just completed miter saw stand and needed to cut the 1/4" sheets for the drawer bottoms. I had 2 pieces of 1/4" plywood. I also had 2 sheets that were faced and were about 1/64" thicker. My choices were to recut the the grooves in the drawer pieces or reduce the thickness down to 1/4" I wanted to reduce the thickness but did not have a zero clearance insert. I looked around the shop for ideas and spotted a pair of 1/8" thick blade stabilizers. I put them both on the saw arbor and that shifted the blade by 1/4", just 1/16" from the edge of the slot in the table insert. That setup worked perfectly.
