Need gluing help, ideas
Gary clarke
I want to glue up a series of boards with varying thickness (1/4 to 3/4) x21 long x 10 wide. Each board needs to be 1 1/2 in ht. the problem that I have had is getting the boards even in ht. I have tried using cauls clamped over each end and I get close to even but no cigar. Any suggestions will be appreciated.
Re: Need gluing help, ideas
Clint Searl
Clint Searl
Upside down on a flat surface.
Yonak
Gary, would it work to do the best you can gluing, making them a bit too thick, then plane off the excess ?
Dick Coers
Don't try to glue them all at once. Can you pin all but the outside ones to hold them flush?
AZ in Colorado Springs
I agree with Clint's suggestion. I accomplish such glue-ups with the jointed (flattened) faces down, on the bar clamps. Then, I just make sure those flattened faces line up on the bottom of the glue-up. After the glue has cured, plane the top (uneven) face and you're good to go.
gary clarke
thank you all for your suggestions
