Did I screw this up?
tom
Hi. I used to be a very regular poster here more than 10 years ago but a move and other life developments (i.e. having kids) have slowed me down. However, I have jumped back in and I could now really use some advice on a project.
I am building a bass guitar with my son from a kit (from Saga Instruments). When we were pattern routing the headstock (the thing at the end of the neck that holds the tuning pegs), after making a pattern out of 1/4" MDF and attaching it to the stock. The bit tore off a bunch of material that was to the right of the bit. The drawing shows the part that tore off. (please see the url for the drawing at the bottom of this post). The other photo shows the part that tore off. Prior to routing we roughed out the shape to about 1/4" on the scroll saw. We were routing from left to right. Using a 3/4" pattern routing bit. Makita router running at speed of about 3 (out of 6). We did a couple of practice runs on an old piece of pine that I salvaged from a pallet. So I figured that if it worked on this board, it would work on the actual headstock, which is one solid piece (not glued up as far as I can tell). I think it is beech or basswood or maybe some asian wood. About 5/8" thick.
Saga is sending a replacement neck (very responsive customer service, by the way).
I have not had much experience with pattern routing. Can you please tell me if I made a mistake or if we were just unlucky.
Thanks
Drawing: https://drive.google.com/file/d/0B1h6u0kbt7c6WkJDdW9WamZjNms/edit?usp=sharing
Photo:https://drive.google.com/file/d/0B1h6u0kbt7c6Q2JMZFFLbkhBMkE/edit?usp=sharing
