I have been using paste wax for various things for years. Had a can of Johnson"s and when it ran out I got a can of Myland's. The Myland"s does not seem to work as well for making thins slide as the Johnson's did. I am thinking of the Beis fence on my TS. I think I recall using the Johnson's on it and it worked well. The Myland's not so much. It seems to accumulate some crud and be a little sticky.
Am I right or am I just longing for the good old days? I am finishing a chest of drawers and will want to wax the drawers. I want to get it right. What wax do you use?
Buy some pure Carnuba, the hardest wax commonly available. Dissolve in warm mineral spirits or xylene. Put it in your empty Johnsons can. Do not use turpentine or the wax will smell nice but take forever to dry. Use it for slidey metal surfaces and drawers.
It sounds like you aren't getting all the excess wax buffed off. I've mostly used BriWax and Butchers (the shop I worked for ages ago liked that one), and at some time I remember having that sticky feel - too much wax still on the surface. Can't remember which brand it was though, or if it even mattered which.
I originally bought probably six cans years ago when I read somewhere they were planning to stop making it. Even though it turned out they didn't, it was no longer available in any of the grocery stores around here. Only place I still see it is at Lowe's.
I'm about to the end of the open can I've been using for some time. Through the years I've used it for any number of things in and out of my shop. I also make it a point to put a little in a plastic container and give it to my furniture customers whenever I deliver something I've built them. I also use Briwax on antiques I work on or on finished surfaces that are cured. It's great at cleaning a surface and leaves a higher shine than the Johnson's.
Yep, I figure I have enough left to more than last me!!
I think I bought the Myland's when I couldn't find the Johnson's. I really can't remember what happened to the can of Johnson's. I will look at Lowe's to see if they still have it. And I will hunt for carnuba to see if I can buy some and make my own. Or maybe I will just go over to David's house and try to look pitiful.
I used a lot of block Carnuba wax years ago to coat transfer mold cavities used to encapsulate electronic resistors. Looking at the web I have found many sources with pricing & shipping varying a great deal. Just wondered where you buy yours I would like to get at least a 1/2 pound or a pound. It is an excellent wax to apply hot (melted) to lubricate many metal to metal parts as well as a great product to mix with Beeswax and/or paraffin and solvent for other uses. It can be used pure (mixed with a solvent to apply) to use on wood finishes but is quite hard to polish off in my opinion. I do use Briwax, and other (more expensive) commercial blends, but agree with you it is cheaper and better to mix your own blend to obtain the finish you want. I haven't had any in my stash for several years so about time to buy some.
There are a lot of perfectly good wax products out there -- Goddards, Johnsons (including Bowling Alley Wax for heavy duty applications), Claphams, Trewax, Circa 1850 and Renaissance Wax, to name a few -- and I've come to regard a lot of them as interchangeable, though I think there are some legitimate restoration claims about microcrystalline waxes.
For a while, I made my own paste wax from #1 carnauba and a mineral wax called ceresin, dissolved in warm (odorless) paint thinner from the art supply store. I experimented with a lot of different mixtures and I seem to recall a 50-50 mix of the two waxes worked best. You need to make sure you mix enough thinner in there to make the paste thin enough to spread easily, and you want to spread it out very thin, or else it'll take a lot of elbow grease to buff out.
Ian Kirby mixes ground-up white beeswax with turpentine for his drawer treatments. Beeswax is a rather sticky, low-melting-point wax, but it works nicely on drawers, and smells nice, as Bill mentioned.
Whichever way you go, remember that the final wax coat should be very thin -- I want to say only one or two molecules thick, but I'd probably be out on a limb there. At any rate, subsequent coats only become part of the existing coat, so don't worry about that dreaded wax buildup that you heard about in those old TV commercials.
I buy the cheapest place I can find on the internet. I haven't needed to buy in several years so my information is out of date. I recall from last purchase that some prices were vastly higher than they needed to be. Somebody should buy 50 pounds and offer it by the pound on WC classified.
I've been using Minwax for many years. Always been happy with it. I'm on my second can since around '95. I use it for furniture, machines, jig surfaces, etc.
I bought a small tin of conservator's wax. Nice stuff, but very expensive.
1. Appearance-here one needs to be able to buff out and not have to deal with a thick coating
2. Lubrication of slidey things- looks and ability to rub out are irrelevant. Durability is everything. A thick coat doesn't matter as any extra will wear off. Personally, after shellacing the insides of case goods that have drawers I slather on the pure hard and durable Carnuba on the sliding and bearing surfaces for the drawers. I do put less on the drawers sides. Any extra self polishes with use. Ditto for planer beds and the like.
Over the years I've use a number of different paste waxes. I find most are very similar. The one that you should be careful about is BriWax Original. The original Briwax was formulated as a "restoration" wax. As a result toluene was used as the solvent/thinner. It is an aggressive chemical and does a nice job cleaning up old, dirty finishes and surfaces. However, it will attack freshly finished oil based finishes And should not be used on any oil based finish newer than 10-12 months. 10-15 years ago, Briwax reformulated a version called BriWax2000 that does not damage oil based finishes. Like most other waxes, it uses mineral spirits for its thinner/solvent. It can be used on oil based finishes that have dried for 4-8 weeks.
Both versions of BriWax are available in woodtone colors.
I am surprised that Bill is suggesting carnuba anyway. I use beeswax. That stuff is superhuman. You can put a blob of it on a center, and run it at high speeds that burn up creepy high tech lubes, yet it will not burn up the beeswax. Incredible stuff. I use it on plane bodies if I want them to slide like crazy.
