Touch up pen
gfriend
I recently used a water base lacquer from target coating. need to touch up a spot (ding) I assume I would have to use a water base touch up pen?
Touch up pen
gfriend
Likely not
the solvent the film former was formulated in has little relevance to what will stick to the finish when it is cured. Test if you can, but I expect any finish will stick to the Target finish.
Re: Touch up pen
Merle
You can try sanding the spot lightly with 320 or 400G AO sandpaper, wipe the dust off with 50/50 DNA/H2O, then re-applying the lacquer to the spot. HTH
