Welcome to our 86th bi-monthly survey for our "News & Views" column in Woodworker West magazine. I thought that, to kick off our 15th year of soliciting your opinions on just about every aspect of woodworking, we might get back to a hands-on topic: How to deal with bugs in wood? I know we've tossed this one around many times on the 'boards, but here's a chance to review and update some of the strategies you've developed for dealing with the critters. What bugs have you dealt with? How did they get there? Are there sure-fire ways to kill them before they do irreparable harm to your wood? How can you protect valuable wood from infestation? What, if anything, can we collectively do to help keep species-threatening insects from wiping out what's left of our ashes, pines, hemlocks, walnuts, elms, chestnuts and other vulnerable woods?
It's all about bugs, folks. Tell us what you know...
As usual, I'll be boiling your responses down to a page of pithy pronouncements for the March-April issue of Woodworker West so we can share our collective wisdom and experience with their readers.
We have dealt with the storage of thousands of bdft of hardwood lumber for a few decades. What follows is our experience.
What bugs have you dealt with? carpenter ants, boring bees, powder post beetles)PPB). I have seen PPB in oak, poplar, walnut and their most favored species, ash.
How did they get there? It think they are an example of the supposedly disproven theory of "Spontaneous Generation".
Are there sure-fire ways to kill them before they do irreparable harm to your wood? Yes indeed. Commercially lumber is dipped in something to kill bugs and mold. It used to be a relative of pentachlorophenol ("penta"). I don't know what is used now days. I have never experienced a PPB bug problem with wood sprayed with Lindane before storage and I have some that has been stored for more than 20 years. I expect that any equivalent persistent insecticide would work. The other bugs are not so destructive. I don't know anything that will prevent a boring bee from boring. They bore cedar and even treated wood. Carpenter ants can invade dead packed wood. Never seen them invade wood on sticks.
How can you protect valuable wood from infestation? see answer above
What, if anything, can we collectively do to help keep species-threatening insects from wiping out what's left of our ashes, pines, hemlocks, walnuts, elms, chestnuts and other vulnerable woods? Stop importing nursery stock and wood that is not KD. BTW, the 1000 Canker disease is native. Donate to organizations that are working to develop resistant trees, for example the American Chestnut Foundation. Obey quarantine restrictions.
I've only had one problem with powder post beetles in pear wood, the more expensive the wood the more they like it. I ended up taking the wood to a place the fumigated import products and they ran it with some other stuff.
The next step is to go through the wood pile and make sure there is no more infestation and either treat or throw out the wood.
The bugs got there from some locally harvested lumber.
The other treatment method that I know people use and is effective is to find a commercial walk in deep freezer and leave it in there for a while.
As I harvest most of my own wood now, my procedure (successful so far) has been
1. Don't hold in log form, saw as soon as possible.
2. Rough boards are then Chloroxed and powerwashed (1800-2400 psi)
3. End seal and then flood with borax solution.
4. Surface dry, dust with dry borax at the edges, then stack, sticker, and tarp with the ground under the stack sprayed with pyrethroids every couple of months.
I believe 133º is the magic number to be attained to kill all boring insects, and their eggs.
I have a cheap / simple way that I have been using for the lumber I have sawn on my mill. I have a Woodmizer LT15, which I got about 15 years ago. Most of my wood gets stacked and stickered and covered with tin to air dry. Sometimes it may sit out on my lot this way for 4 - 5 years, and on occasion, PPB have gotten into the sapwood of the older stacks of W Oak, and all through some R Oak.
When I bring a air-dried stack in to use, I stack it again with sticks to space between layers, then suspend a sheet of 1" thick foam insulation board about 4" above that with a few blocks. Then I drape a tarp over that, letting the sides hang down a couple of feet lower than the bottom boards. I then place a small space heater at one end, in a little door which I have cut into the tarp for the heater, and turn it on. I make sure it is a couple of feet from the end of the boards, to avoid combustion. It oscillates, blowing it's warmed air all through the stack. Since the air is coming from outside the tent, the heater's thermostat never gets satisfied to turn of, so it just keeps heating. And the warmed moist air escapes from the bottom of the bubble formed by the tarp, takes away the moisture picked up from the wood.
This also will take my 12% MC wood on down to 6 - 8% in a couple of days. I just ran some R Oak, which got up to 130º after one day, then 140º for the second day, which satisfied me for both dryness and the possibility of critters.
Other than the methylene bromide fumigation, or whatever they have come up with to treat for the termites which don't require earth contact, I thought it was unlawful to apply a poison to wood, then sell it to someone else. Besides most do not penetrate into the wood if they or eggs are already there. If you are finding the frass, this is from exit holes made by the adults leaving to find mates for the next generation, so there are likely others still in there chewing.
I prefer to get my fresh sawn lumber from very recent cut logs. Will spray my lumber with an appropriate insecticide during the air dry stacking. Very few bugs, PPB or other's make it past the chemical barrier I have laid down. When I do find a board with evidence of PPB, it becomes firewood,
