I screwed up the other day when cleaning my Jet Planer! I accidentally cranked the cutter head up to high and now it doesn't want to lower. The handle is turning the gears in the post but at a certain point the handle becomes very hard to turn. I don't want to force it for fear of stripping the gears. Of course the manual is of no help.
I am NOT much of a mechanic so if anyone can give me some help I would be most grateful.
Make sure your hand-wheel is on tight, and that it is turning the shaft it is mounted on. That shaft goes into a gear-box, which sends a shaft down to the bottom, where it has a chain sprocket connected to 4 others. IF you can flip it over, and try rotating the handle, you can see if it turns down there.
Troubleshooting, is the process of elimination. Follow the working parts as far as that path leads.
Also, spray some good lubricant around the top of all four of those post, so the bushings slide easily as you raise and lower.
