200+ woodworking book reviews
Router Stuck in Table
Don Emmerling
I am usually over on the turning side or of late on the hand tool side, however I thought you folks might have more experience with my problem. I have a Makita router that is attached to a Jessem router lift and Jessum table insert. The screws holding the router lift to the table insert have been in there since 1997. There is no evidence of rust as this router table has been in my dry shop the whole time. The screws used to hold the lift to the table need an allen wrench to remove them. I believe there were 8 screws involved and I got all out but two, which only came out after I gained some additional leverage on the allen wrench handle. As for the other 2 screws I have applied WD40 and let soak for 30 minutes or so and I have tried heating the area around the screw but not directly on the screw. With a final try at unscrewing these things the allen wrench developed a significant twist in it. "I am thinking these two screws will have to be drilled out and I don't look forward to that. I want so save the lift mechanism and the table insert for future use. Any thoughts out there?
Thanks,
Don
Re: Router Stuck in Table
what I was taught
I had a similar problem. An old hand maintenance mechanic told me to try the following and it worked.
Soak stuck bolt in penetrating oil. I have been told that WD40 is not the best choice. With the threads submerged under the oil put the Allan wrench in the socket and whack it smartly. In my case the bolt then came off with astonishing little effort.
I think what is going on is that the whack opens a tiny gap that the oil wicks into.
Re: what I was taught
I agree with Bill. I have used PB Blast. WD 40 is not the right choice. I have also used brake fluid. Let it soak longer than you think, 24 or 48 hours. I hold the Allan wrench with a small pair of pliers On the "shaft" and rap the the "handle" with a small hammer. Apply as much force as you dare with the ViceGrips or wrench and hit the handle sharply.
craigd
craigd
The whack works but I think in a slightly different way (with rust anyway): I've had bolts with rusted on nuts, soaked them in Liquid Wrench such that it wicked all the way through and still wouldn't budge. Whack! and off it came. My guess is the blow compressed the rust (or broke the bond) which created the small space that allowed the nut to turn freely.
Note that this doesn't work with aluminum, which galls and creates a huge mess.
Another thought...
I have put a hex driver bit into the socket in the screw and rapped it sharply with a very light hammer like a tack hammer or even less. then let it soak a while and unscrewed it with an impact driver.
Come to think of it, recently when I was fixing my planer, I use my impact driver to remove some screws that would not budge. I was stunned at how well it did. It a Bosch 12 volt impact driver. Not the type used for drilling in concrete, the rotary type for driving screws. This is a good excuse to buy one if you don't have one. Borrow or rent one. I'm betting on it.
William Duffield
Another solvent you might try is half and half acetone and Automatic Transmission Fluid (ATF).
del schisler
pb blaster is probly the best , or break fluid, as far drilling the allen screw's, it would take a very hard drill bit , i belive those are case harden and almost imposable on drilling , like was mention a sharp hit to the bolt and soaking has to work good luck WD-40 the wd stands for water displacement , not what you want, my opion over rated for what people thank it is used for their may be what you call electrolysis like on a boat where alumum and iron are togother they tend to bond??
also post over on this web site , i am a member for yrs and lot's of router info their http://www.routerforums.com/
Get some good wrenches
Lee Schierer in McKean, PA
Good allen wrenches should not twist. Get some Bondhus allen wrenches. They are sized better and are much stronger. Note: on your stuck bolt do not use the ball tip type allens as they may break off.
Lee
Re: Another thought...
Mike from Suffolk VA
Barry is correct here. I have done submarine maintenance work for years. Salt water = corrosion. Very common problem as they use a lot of Allen hex screws and bolts. We place the Allen wrench in the fastener apply force in the loosening direction and smack it with a ball peen hammer on top of the wrench directly over the fastener. People have suggested using penetrating oil. That is good idea, but not required. When we used penetrating oil we used Liquid Wrench, Kroil, PB Blaster, Marvel Mystery Oil, and oil of wintergreen (smells nice). However, when we did not use the penetrant it still worked. Part of the theory of tightening a fastener (torqueing) is that you are actually stretching the fastener. We had some jobs that required us to use a predetermined amount of stretch. We had to measure the bolts prior to installation (the bolts were hollow) and tighten them to a certain length. We measured them with depth micrometers. We then adjusted the torque to get the length that was required. On some car heads you seat the head bolts to 60 foot pounds and then rotate the bolt heads a specified number of degrees. It is the same principal here. I believe that when you “shock” the fastener with a blow from the hammer while trying to loosen it you momentarily change the length of the fastener which allows the fastener to turn. I just recently had to change the blades on my Rigid planer and because of a previous post made by Barry, I tried the tool that came with the planner to loosen the screws holding the blades in place and they did not want to budge. I got my cordless impact driver and the right bit and they came out with no problem. I believe the impact or shock from the impact carried down to the fastener and allowed it break loose. I did not use any penetrating oil and had no seizing or galling when the screws were removed.
Don Emmerling
Thanks for all the ideas. I too am reluctant to try and drill it out. What is PB? Thanks again.
Re: Router Stuck in Table *LINK*
David Yoho
PB Blaster is a penetrating oil. Check the link below.
I think the advice about using a sharp knock or using an impact wrench should do the job for you. Try it and see.
PB Blaster
Robert Fuller
Are either of the parts these screws hold/attach to made of plastic? If so, this idea will not be wise to try.
If all metal then get a 30W or higher soldering iron and apply it to the screw, preferably as close to the stuck threads as possible. Let it heat up the threads for 10 minutes and then try removing. If that fails, heat it up again, then quickly cool it with an ice cube and then remove the screws.
95% success rate with this method when I worked for Rockwell Communications back in the 70s.
