finishing miter joint with contrast exposed spline
Kurt
I am building an oak picture frame which I want to finish with a dark stain. To strengthen the glued mitered end-grain joints I am going to use exposed splines. I want a decorative effect with the splines, so I will use maple for them. I do not want to stain the maple so that there is a contrast between the stained oak and clear maple splines. What steps should I take? I am thinking I should glue the frame to together, cut the grooves for the exposed splines, stain the frame, poly the splines, and then glue the splines into the frame. Would gluing the maple splines after they are finished affect the strength of the joint? Should I care?
Re: finishing miter joint with contrast exposed spline
William Duffield
Using poly prior to gluing would have disastrous effects on the strength of your glue joint.
Maple takes stain more reluctantly than walnut, but you might want to consider a lighter, denser wood than maple, e.g., dogwood, boxwood, or holly. Or, even white Corian.
I don't understand how you are going to sand or scrape or plane the spline flush with the walnut without removing the stain you are putting on the walnut.
If you choose a spline material with very low tannic acid content, you can chemically darken the walnut with ammonia (fuming) or iron acetate (rusty steel wool in vinegar).
Another option is to install the splines, sand them flush, shellac them with a fine artist's brush and then stain the frame.
Whatever you do, experiment with scrap first to make sure you get the effect you want.
I wouldn't do it that way
...for reasons William has outlined.
Funny, I had an e-mailed question recently from a fellow on this exact subject and I didn't have a good answer for him. But he came up with something that worked: He splined the joint and then fumed the frame to darken the oak. The ammonia fumes don't affect the maple -- at least not as much -- so the contrast increases.
Of course if fuming won't be dark enough, you're back where you started. If anything, I'd probably seal the splines with blond shellac or lacquer, using a tiny little brush, to prevent them from absorbing stain. You might need several coats to seal them adequately, but you can find this out by running some trials.
Let us know what you do and how you make out.
Ellis Walentine, host
WoodCentral.com
Re: I wouldn't do it that way
paul in AZ
If you are going to use lacquer to seal it consider getting a bottle of clear nail polish [=lacquer]. The brush that comes with it can be trimmed even further to get an applicator fine enough to use.
Robert Fuller
+1 on installing splines BEFORE finish OR stain, Sanding flush, then seal splines before staining. After staining you can then finish the entire frame.
