Using West System epoxy to fill deep voids
Royce Meritt
For the past couple of years I have been using some Burr Oak from a huge tree where my wife grew up. I had the tree milled and kiln dried. It isn't the greatest material due to knots and other imperfections but on the right project I like the "rustic" look of the wood. Over time the pile has become pretty well picked over and I am left with the pieces with a lit of larger knots, voids and other imperfections. In the past I have used a mixture of wood glue and sanding dust to fill minor imperfections, mixing up a batch about the consistancy of peanut butter. So, on to my question...
This time, because of some larger imperfections I would like to use West System epoxy to make my "wood putty" due to the larger voids, knots, etc. To what consistancy should I mix sanding dust into the West System epoxy so that I still get a good color match but not lose the ability for the epoxy to "flow" into the voids? Any other thoughts? Thanks.
Hope that all made sense!
Re: Using West System epoxy to fill deep voids
Tom
There isn't a single answer, it is fairly forgiving. I have used a lot of WEST, and in a similar situation I have used it to patch Cherry, and other fancy woods. If the area is large, you need to concern yourself with heat, basically do it is several stages. I generally prefer to use a more epoxy than not mix. I wouldn't call it a putty I can pour it out of the cup into the hole. Sometimes the sawdust blooms and fills a lot of space and won't settle, which is why I prefer finer materials. Also, if you mix it into whatever thickness with sawdust, or even wood flour, the epoxy can still ooze out of the putty, so you may need to leave some wetness in the mix so you can add some colloidal silica to actually hold the epoxy from drooling. Of course if it is a sealed cup you can throw it in there and it will hold it.
Cherry is an easy one, because one can just tint it black with graphite powder, and it matches the pitch pockets. Over the years I have come to prefer mixing in dye or even using raw epoxy. One really can't get a good colour match when mixing in the same wood one is filling. (There are techniques when filling tiny flaws in stuff like guitars, using super glue, and the patch is pretty much invisible.) One option is to use a lighter donor wood, but I just prefer dye, or those earth tints. A contrast as in making the mix look like something a lot darker is good if the wood provides for it. Or you can go right to red, as was popular at one time.
I keep some wood flour around from System 3 a very inefficient admixture, but it does mix in smoothly, and is the right colour for something. In theory you can make your own flour by osterizing sawdust, and flour also can be accumulated from power sanding tools, or dust bags.
If you are going for a colour match, one other thing to think about is that if the epoxy matches the raw wood, the epoxy will stay the same when you finish it, while the wood may change a lot, as it typically does under finish.
It may sound complex, but it is just a mater of thinking ahead, and trying to figure what the main problem is and designing your mix to accomodate that. There is a rule of mixtures whereby a mix takes on the properties of the materials you mix. So you can take some liberties and still get a pretty good product.
2 Steps
mix your epoxy first and use a glue brush (plumber's flux brush) to work straight epoxy into the nooks and crannies so you've got the surface wet. Now mix in your wood flour to do your paste and apply with a knife or spatula in whatever consistency you fancy. You want to be mindful of thickness, however because epoxy cures by chemical reaction so the larger the thickness the more heat is generated which can wind up fracturing and separating from the wood. Even with wood flour addment, I would not apply at more that 3/4" thickness at any one time.
Note too that when set and sanded off level, your fill will display air holes that you can then fill with more epoxy.
You do have another option which is to forego the dust and fill the void with resin which can be left clear, tinted with dye, or use inclusions like crushed mineral or colored chips like many turners do. Here's an example of what the clear can do in a walnut slab.
Raw:
Filled:
William Duffield
If your knot goes all the way through, you can seal the bottom with clear plastic packing tape to keep it from running out onto the floor. After the epoxy has cured, the tape peels right off, leaving an almost finished surface. If you apply the tape to the top, turn the board over and pour the unthickened epoxy in from the bottom of the through-void, most of your air bubbles will rise away from the surface and will not have to be refilled.
Always thoroughly mix your resin and hardener before adding any thickeners or colorants.
Air Bubbles
In straight resin, you can remove all of the air (mixed in) with a shop vac and a few items.
You make a vacuum chamber that you can see into. I use a 5 gal bucket , a piece of glass or plexi to make a see-through lid, a bit of rubber to get a good seal at the rim, and a fitting for the vac hose.
Cut/drill a hole near the bucket rim and glue in the fitting.
To "degass" your mixed resin, pour it into a container that is twice as high as the mix (1 cup in a 1 qt pitcher).
Put the pitcher into the bucket, put on the lid, and start your vac. Watching your resin in the pitcher, gently connect the vac hose and you will see the resin start to foam up. Remove the vac, allow the foam to settle. Repeat the suction/release step until the resin doesn't foam up any more.
Your resin will be clear and free of air bubbles if you pour it carefully.
brake-ing the air bubbles in expoxy
del schisler
use a hair dryer and blow heated air over the expoxy , or use a small tortch but you have to watch and not get to close, you can see the bubbles break when you pass the flame over the wet expoxy, now do that at first than in a 1/2 or so do it again and more bubbles will break again , now let it cure, it will be crystel clear, i used to pour cypress clock's when they were selling, i probly done 500 or so, we used the tortch, if you havent done this before, do a test piece, now if it boil's let it go ahead and cure, now take a disk sander and use 50 or so grit and sand down , blow the hole clean and make another pour and do it again, the sanding mark's will disapear, been their done that on the cypress blank's we use a black patch for holes , now don't let expoxey drip on concrete or it is their to stay good luck
Re: Air Bubbles
John in NM
I'm surprised that a shop vac is up to the task, I never would have thought to try it :D
Doesn't take much
by way of pressure reduction to pull the gas out of the liquid. You need a real vacuum pump if trying to get penetration into wood as in stabilizing.
Yeah....
John in NM
Just surprised it takes as little as a centrifugal fan provides :D
I degas casting resins and rtv silicone in a chamber made of an 8" PVC coupling and some plexiglass. Takes a bit more with the silicone due to the higher viscosity, but if you can degas West System epoxy with a shop vac, then it would work with the resins I use. Probably need a smaller chamber though. That's one to file away in case I ever leave the job with the really nice vacuum pumps :D
I did some test with several shop vacs
Keith Newton
about a year ago. Most would pull -1 psi. or slightly more.
As for coming up with a larger chamber, one that I have, is an in-line filter for a vacuum line, that I salvaged from a piece of equipment, which used a glass mayo jar for the collection vessel. I can immerse a piece of wood in it, pull a vac, and watch it fizz.
AS for something larger, some years ago, I was experimenting with using vacuum to dry turnings faster. I used an abrasive wheel to cut the top off an old well pump pressure tank. It already had plumbing fittings coming in. All it took to seal the cut-off top to the tank, was duct tape. I didn't get the results I expected, mainly due to a lack of having a heat source in there, and soon decided it wasn't worth the trouble, since two weeks in a paper sack was hard to beat for being easy.
Lately though, I've been thinking about pulling it out again for some more experiments with some thin epoxy penetration.
(Message Deleted by Poster)
PVC works great...
John in NM
Mine is large enough to degas a gallon of resin (I usually degas after mixing, so usually only do a disposable cup at a time), and was very quick to build, an aluminum bottom glued on with silicone caulk and a 1/2" plex top with a self adhesive rubber ring for the seal. I did the plumbing through the bottom, but there were other reasons for that. The plastic coupling is heavy enough to thread a hole in the side, making plumbing much more simple.
Since I'm degassing mixed resin/catalyst, speed is important, which is why smaller is better if I end up having to use a low volume pump one day. Currently I can use a surplus pump at work that moves something crazy like 17 cfm - it gets the chamber to just a few psi in seconds and will easily boil the resin at room temp.
This is also a case where using an old air compressor as a vacuum pump could work well. It probably wouldn't develop the vacuum to degas mixed material, but it would be fine for degassing unmixed epoxy or resin where time isn't a worry. As I recall, they usually get to 1/2 atmosphere or so, maybe a difference of 7 psi.
Robert, i didn't mean to offend you on Punctuation
del schisler
i been out of school for 65 yrs and i guess i need you to show me how to do the Punctuation ? i didn't mean to offend any one i am sorry , i was just trying to help a fellow , sence i have don so many and all mine were good, i done bar top's also and they turned out ok i guess i will be in the cloud thanks for reading
Re: Robert, i didn't mean to offend you on Punctua
Tom
Content is more important than style. Both help. Remember that the period of correct spelling, pronunciation, and syntax is a relatively short one, presumably post Gutenberg. Doesn't seem to have made that strong an impact in the US, where they invented their own spelling, and put a heavy emphasis on standardization around a grade 3 level of understanding. If you doubt that, watch a French newscast. Or more accessibly, watch an English golf commentator VS a US one. So thanks for the input.
I have been butchering the language again since I got a tablet, and am thumbing my prose at the world.
Different Application
Del,
The flame trick works perfectly well on thin coatings like poured bar tops because the hardener used is a relatively slow-set type, the little bubbles are close to the surface, and the heat acts to thin the viscosity of the resin and allow the bubbles to rise more easily. When you get into essentially casting thicknesses of more than 1/4" thick, the heat, as mentioned, works against you to speed up the set and trap the air in the resin. The trapping effect gets even worse when you go to thicknesses like 3/4-1" which take special reagents and may have to be cooled to control the reaction heat.
peace
Question on shop vac/ container?
Why not use the vac itself as the container? Just put your item in the vac, Seal the inlet and turn it on. You could not see what was happening, but maybe you could install a view port, If you really needed to.
Because
You'd kill your resin with all the dust still in the crevices of the machine. With the outside chamber you get crystal clear resin. Obviously the chamber (bucket) has to be kept clean.
thanks Mark, this was what my take on it
del schisler
if their were a mention of that thick of a pour i didn't see that , than a different take on that, i never did that thick of a pour, so i took it as a thin pour, guess i should have read it twice? oh well another post later thanks for posting Mark
You're okay, Del
I learned early on that the most important thing about communication is getting your point across. I think you do that pretty well. Thanks for your contributions here.
Ellis Walentine, Host
Del, I have been out o school 43 years and I just hope I am still on the sun lit side of the turf in 22 more. Its hard to imagine participating in this technology isn't it? I want to thank you for taking the time and for conveying as much experience and content as you do. Thanks.
Re: Del I certainly appreciate your insight.
Yeah, you do make a few punctuation and spelling errors but I don't visit this site for an English lesson. I do come here to learn from others - and have greatly expanded my knowledge (although my skill level may not have kept up ;) ). I visit this site about every day and also a firearms site (I am also a collector of firearms). I really think anyone that posts to correct another persons English, spelling or punctuation is extremely rude. In my experience those people normally don't really have much knowledge about the subject the rest of us are interested in pursuing. Apparently they believe they can impress the people by doing what they do, obviously the opposite is true.
Keep on posting - 99% of us on the site appreciate your posts - (the rest don't matter)!
Robert Fuller
I was not trying to be rude, but I think that poor grammar and spelling should be brought to the attention of the person so they can make corrections. Maybe it was caused by a bad keyboard on his PC and he had not noticed yet. Or maybe he used a cell phone to post that and his cell phone was not working properly.
I was just trying to raise awareness.
I have only been out of school (high school) for 38 years, so I guess I still have a lot to learn.
Fagedaboudit
Everything you really need you learned in 3rd grade.
Da rest am gravy ;)
Del is right, torch works well
Grant in Iowa
I have used a torch for heat (which is different than applying the torch flame directly to the epoxy) on epoxy quite a bit. You can also use a heat gun.
Never the caution from others, it works to drive the bubbles out. My estimation is the heat reduces the viscosity of the epoxy enough that the bubbles readily float to the surface and break, leaving the epoxy to level out nicely. These type of repairs aren't usually needing maximum strength, so having the epoxy cure earlier than it normally would isn't a huge deal.
I use epoxy mixed with pencil lead (graphite) quite a bit to fill voids in boards. Burnt umber or darker pigments can also help the epoxy blend or be dark enough to imitate a pitch pocket or dark knot nicely.
FWIW,
Grant in Iowa
Re: Fagedaboudit
I do Expert Witness testimony. Learned everything I need to know in Kindergarten. Go sit in the hall, don't talk to strangers, and tell the truth.
