Samantha's dresser 4-dovetail sockets, fun to make
Chopping the dovetail socket
PIC1
Picture 1 shows the goal of this step, a snug fitting drawer divider. Ideally the dovetail should slip together with just hand pressure. Too tight and there is risk the joint will seize upon assembly. A loose dovetail can be shimmed. However, with all these dovetails holding the case together it matters not if the occasional dovetail is loose.
Note: I will be covering up the joints with facing later in the build so I am not fussy about how they look on the exposed edge.
Note: The flat side of the half dovetail is oriented up toward the top of the case. To put it another way, the flat side of the dovetail defines the bottom of the drawer opening and the angled side defines the top of the drawer opening below. It is critical to not get this orientation backwards or the drawer opening for the top drawer will become smaller than what was planned and the drawer runners will not be aligned with the dividers.
Traditionally, the dividers in the back of the case would be tenoned into the case side. (When I refer to the “case”, as in case goods, I mean the box that will become this chest of drawers, or any other box-like piece of furniture.) It saved labor the way they did it then. The approach described here is so fast that I just dovetail all the dividers to yield, as Steve Hamilton described it, a “fortress” like structure.
I learned this technique for making the sockets at the Headley shop under the guidance of Steve Hamilton. It is fast and precise. After doing 2-3 sockets one learns exactly where to position the guide block and the fits become perfect without needing further adjustment of the dovetail.
Pic 2
Set a marking gauge to the depth of the dovetail on the dividers. Transfer this depth to each dado in the case side. This depth will be the depth of the mating dovetail socket.
PIC 3
Preparation of a “sawing guide block”, a “paring guide block” and a “socket width gauge block” makes this process go faster and more reliable. Saved, they can be used for the next project. The sawing guide black is just a piece of wood about 1.5” tall and square on its sides. It is a guide for sawing the depth of the socket. If you are good at sawing you will not need it. Saw down to just the depth of the socket. I don’t use the guide block to saw what will be the angled opposite side of the socket. It will be pared to exact width in a later step. Note, the saw has teeth all the way to the end of the blade. It is hard to describe in words how to do it but with a bit of finesse of the saw a stopped saw kerf can be made to define the socket. It is not necessary to do a stopped cut for the saw kerf will be covered up with the drawer runner.
I find it best to do these steps in series to aid “muscle memory”. Saw all the sockets on one side of the case side. Then chisel out all the waste on this side, etc. This approach will make setting the chisel guide block more precise, as described below.
Pic 5,6
Chisel out the waste between the saw kerfs and refine the depth with the router plane set to the exact depth of the dovetail on the end of the divider. The Lee Valley router plane is a dandy too for this task. It is easy to adjust and that feature is important.
The next step is to widen the socket to precisely fit the dovetail. Practice on a scrap piece till you learn exactly where to line up the paring guide block. I am not very hand tool skilled, yet after 2-3 sockets I can nail them perfect to where they just side together with hand force, just as is needed to prevent loose a joint or glue seizing during assembly. Doing one socket will take about 6-7 minutes when you get the hang of it. It becomes rewarding when the test fit just slides together and you become confident the next one will do the same.
Pic 6,7
Pictures 5 and 6 show the sawing guide block and the socket width gauge block. Picture 5 shows the block used for the saw guide and the second gauge block used to mark the width of the socket to be pared in the next step. The pen line, made with a Pilot pen, will show where to position the chisel paring guide. (Pilot gel ink does not wick into wood and shows up great even on walnut)
PIC 8
This picture shows the paring guide block used to guide the chisel for paring the angled part of the dovetail socket and establishing the accurate dovetail width. It is angled at 14 degrees to match the divider dovetail. The bottom edge of this block is aligned with the pen lines, see Picture 6. While it may sound daunting indeed it becomes easy to align the guide block on the relatively wide line to get a finished socket perfectly sized for the dovetail. The wide line is actually an aid. For one, you can readily see it. After a few practice cuts the exact position of the block edge on the line is found. Amazingly, it becomes easy to repeat this setting as successive sockets are pared. For all the hand tool stuff I can’t do reliably (like joint a board edge) I find this one is easy, so it must be easy to learn.
The waste is best pared out with light arcing cuts. The chisel handle is about 45 degrees to the board surface. Plunging the chisel straight down does not work well. With a sharp chisel it goes quickly and reliably.
Discussion: This socket must be just a few thousandths of an inch wider than the dovetail. It may seem an impossible task to get it this precise. It isn’t. During some test cuts the gauge block is sized so the pen marks are very close to the correct width of the socket. By design, a relatively wide pen mark is used to establish the position of the paring block. The wide black pen line is easily seen while positioning the paring gauge block. By making practice cuts one learns where on the pen line the paring block needs to be set- centered, just covering the near edge, etc. As one gains experience setting the block and paring the socket, the precise position of block on the line becomes established. A reminder, always err on the side of too small. The flat face of the divider can be planed to make the tail fit the socket. An occasional loose fit is not a problem. The more abundant tight ones will more than hold things together.
