Samantha's Dresser Part 3- making the dividers
Samantha’s dresser Part 3 Making the dividers with a handy jig
In the previous installment it was claimed that dovetailing was to best way to hold a case piece together. The challenge is to come up with a way to make the parts easily and precisely so fitting and assembly is not a nightmare.
After the divider stock is ripped to width and planed to thickness. The lengths are cut on a saw sled with a stop. I can not overemphasize the value of a saw sled for cutting parts square and cutting multiple parts all exactly the same length. I used to have to diddle with wide cuttings to make them square. With the sled they are cut square right off the saw.
I made this handy jig to cut the half dovetails. The tails will be exactly the same even if the lumber varies slightly. It took five minutes to cut 24 tails and they are precise to 0.001”, a desirable situation for eventual fitting.
I have been criticized for using half tails. Their advantage comes in the fitting. The socket will be cut so any error is on the side of too small. A quick pass of the plane across the flat side of the tail will remove a tiny shaving to yield a precise fit. Anyone that thinks them inadequately strong hasn’t seen first hand how stiff the case will be. The last chest of drawers I made was described by Steve Hamilton from the Headley shop with the words “fortress”. A precise fit enabled by the easy adjustment of the half tail trumps the slight mechanical advantage of the double tail. But if you can do double tails and get them to fit, fine. I can’t.
Finally, a slot is cut in the back of each divider to receive the tenon of the drawer runner. I make this cut with a solid carbide ¼” bit. The carbide in these bits is different from, and lasts longer, than the welded carbide bits. Using a stop block on the router table I run the piece into the cutter, centering it as best I can. I then run the piece in from the other side which ensures a perfectly centered slot. It matters not what thickness the slot is for the tenon will be fitted to it. It is important that it wind up centered.
Re: Samantha's Dresser Part 3- making the dividers
William Duffield
I have at times criticized half tails, but that is not a general criticism. It doesn't appear to be at all applicable to this thread and your photos. For through dovetails, in either carcass or drawer construction, if they are cut and fit by hand, if the half tail at the end is not trimmed precisely, there is the risk of a fat pin splitting the tail board due to the wedging effect. With the precision of your setup, I think there is very little risk of that. Studying your photos, I see one board with full tails, that will fit a board with half pins. No problem there. I also see a half sliding dovetail. No problem, there, either, since the half tail is in compression, not tension.
I suppose there is also the possibility of a half blind dovetail laid out with half tails, but I can't recall ever seeing and example.
Thinking back on my warnings, I realize I have not been clear enough regarding about the ver special cases where half tails should be avoided.
Joe in a Cleveland suburb
I just happened to be looking at a 2003 issue of FWW and it had an article on various methods of case construction. Just an FYI...
You should write an article for FWW.
Looking forward to Part 4.
I like your handy jig for cutting the half dovetails. I have been cutting mine by standing the stick up on the router table against a tall fence. Your fence looks like something I would make except I don't have a piece with the dovetails in the end.
It seems that if you have an equally consistent way of cutting the sockets for them and you always use the same size sockets, you could screw the fence onto the jig, making it fairly permanent. Do you have a vertical in the jig to assure the work piece is aligned? May not be a problem, but you could put side stops on to protect the surface of the jig from further incursion.
Is your router well enough centered to avoid variations in the DT if you rotate it or do you just not rotate it?
answers
It seems that if you have an equally consistent way of cutting the sockets for them and you always use the same size sockets, .......I don't always cut the same size dovetails. Depends on case side thickness. For this 3/4 sized chest of drawers I am using 3/4" sides. For a full sized piece they would be 13/16 or 7/8 and the dovetails would be deeper.
Do you have a vertical in the jig to assure the work piece is aligned?....th e top and bottom opening serve this purpose.
Is your router well enough centered to avoid variations in the DT if you rotate it or do you just not rotate it?....don't rotate. However, one can adjust the dovetail size a small amount by rotating the router. there are times when this trick can be used.
