Design and Cut lists
When I started to build stuff I approached it with a "modern" manufacturing approach. This is the approach to be found in magazine plans. I drew the plans, meticulously calculate every dimension, cut parts and assembled them. They fit more of less. There is another way that I wish I had found earlier in life.
The two pictures show what I start with to build something- a scaled drawing and a rough cut list of major parts. For furniture that doesn't have curves I find that if a scaled drawing looks well proportioned, the finished piece will be. I wish I could make drawings on the computer like we have recently seen, but it seems too daunting to learn. From this drawing I calculate the approximate size of the major parts and rough cut the parts that define the major dimensions of the piece.
For Samantha's chest of drawers the lumber "told me" that a chest a bit taller would capture some pretty grain at the end of the sides and that a chest a bit wider would center this grain better. So, the piece will be 1 1/2" taller and 1 " deeper than the drawing.
When the pieces for the case sides, top and bottom are cut to finish size the overall size of the piece is established. From here on as much as possible I take dimensions off the piece at hand rather than by calculation or ruler measurement. This way avoids measuring errors. Second, I mark lengths on pieces to be cut with a marking knife which establishes a length more precise than with a wider pencil mark.
For example this morning I am cutting the drawer runners (the pieces that run the width of the piece that support the drawers. I hold the rough cut runner at the place it goes, mark the length it needs to be with a nick of the marking knife and go cut it. No chance for ruler measuring errors and the length is established to only a few thousandths of an inch precision.
Re: Design and Cut lists
Slip Sticks
charlie belden
Bill:
One of the advantages of using traditional joinery is that you can dry fit as you go and the parts will be self aligning and self supporting (though a clamp or two or some big rubber bands may be needed for mortise and tenon joints that aren't quite "spit tight").
Once you put together what you HAVE, you can use "slip sticks" to get distances between things. With the slip sticks set to the distance between two things (cabinet carcase sides, drawer opening, table legs) for example) off to the miter saw, set one end of the slip sticks against a "near side" tooth on the blade and a "stop" against the other end of the slip sticks. No marking necessary and no question of "take the line", "leave the line" or "split the line". After the first piece is cut you can verify that it does actually fit where needed, then, thanks to the set "stop", cut as many parts as you need and they'll all be the same length.
The following explains all that in pictures and some text.
Re: Slip Sticks
William Duffield
For those of us who think they have to have something fancier and more secure than clothes pins, Veritas makes these bar gauge heads.
http://www.leevalley.com/en/wood/Page.aspx?p=32585&cat=1,43513,43553
IIRC, Bill Houghton made a pair from wood and posted the project here.
If you want to use them for checking boxes for square by measuring the inside diagonals, it helps it you taper the ends to nearly to a point.
I like that tip
While I have a collection of these sticks I occasionally have a need for some size not at hand. The idea of making a "temporary" stick with spring clamps will be handy to use in the future.
Re: Slip Sticks
Grant in Iowa
Charlie,
I am guessing the drawings were "just for clarity", and you already know this, but I will write it anyway for those who hadn't thought of one more measuring detail:
When measuring between things, as your drawing shows, I always measure up tight to the top or bottom, and not in the center. This is to ensure that the measured amount will not take in to account any bowed parts. In the case of measuring for... say a center shelf, I might take a measurement near the top, then a measurement near the bottom and use the average for my part.
I do like the slip sticks though.
FWIW,
Grant in Iowa
Re: Slip Sticks
Joe in a Cleveland suburb
I like those Veritas® Bar Gauge Heads thingy's. They are handy.
Re: Slip Sticks
William Duffield
And they're a great excuse to make good use of small cut offs of very nice wood that is otherwise too small to use (except maybe for cock bead), but too nice to throw away.
Re: Slip Sticks
charlie belden
Excellent point. Having an edge of the sticks up against a flat surface - like a top or bottom insures that they're not angled ( / \ )
I pretty much do the same; sketch a drawing until I like how it looks with rough measurements. Then all the final sizes are made while I'm making it.
I've never made anything super complex though. I suppose if I did, I might be a little more detailed with the sketch.
I try to fit and mark things to size opposed to measuring. When I measure, I screw up...
I guess I prefer to make things up as I go. It may not be efficient, but I am a hobbyist and don't need to be.
I've never been one to make exact measured drawings and I don't have the patience to learn Google SketchUp or other type CAD software.
Sometimes though I will make a full size mock up. Right now I am planning a small half round table. I made a mock up out of foam board and cardboard to see if I like its size and proportions in the location it will end up.
Much the same
David Yoho
I pretty much go about a working plan the way you do. Back many years ago when I started, I would sit for lengthy periods drawing and calculating detailed measurements before I started cutting. That all changed when I built my first chest with inset drawers.
I realized I needed more precision for fit than what I would get with all the calculations due to anything that differed from the plan. So, I built the case and then each drawer. Much better!
Today I just jot down what the finished measurements of the overall piece needs to be along with rough measurements for major parts. I note the location of any joinery necessary and fine tune details, making notes as I go. This has saved me a lot of time and troubles. In the end I not only have a project with greater precision but also a working plan I can refer to in case I'm asked to build another down the road.
shop notes
Note that the sketch and cut list is in a notebook. I too recently started making notes in a notebook on the project being built. When faced with a future problem I often remember that I solved it, but can't recall details. The shop notes come to the rescue.
