Off topic electrical question
I know I'm not keeping up with Barry Irby here :D :D , but I do have an off-topic question.
In November or so, I did the finish electrical work in the room we've been working on. The lighting uses three-way switches, one at each door. We're required to have dimmers on the circuit (or else spend twice as much on the fixtures to get high-efficacy fixtures - not a hard choice). The pretty new dimmer switch has now failed, but that's not the question.
In the course of replacing the dimmer switch, I was testing the travelers from the other (we'll call it "main") switch, so I could orient the replacement switch the way I wanted it, and discovered that the traveler that was "off" was still showing some voltage, on the order of 7-8 volts. This was true for both travelers - when I flipped the main switch from down to up, the traveler that had just shown full voltage was now showing 7-8 volts.
Is this normal? I did wrap the switch in electrical tape, as I usually do, and it's occurred to me that there could be minor "leakage" along the adhesive, although you would think the companies making the tape would select something that doesn't transmit electrons easily.
And is it harmful? I generally don't like to see electricity where it shouldn't be, but maybe I'm obsessing about a trivial issue.
Re: Off topic electrical question
Bob Entwisle in NJ
Bill,
Just a thought.
What was the input impedance of the meter you made the 7-8V measurement with?
A modern digital multimeter usually has a pretty high input impedance, often around 10 Meg ohms. It would not surprise me to see 7-8V on a long wire that was disconnected at the far end if the wire is bundled with another pair of current carrying wires.
Older analog VOM type meters generally had a much lower impedance, which would have the effect of shunting the current from the 7-8V to ground, resulting in a low or seemingly 0 volt measurement.
Bob in NJ
Keith Newton
Bill , I'm not an electrician, so probably wrong, but I'll bet because it is laying alongside a hot line, probably with a number of twist in it, this would produce a charge due to its proximity.
Thanks, Bob and Keith
Yes, there are a lot of wires running in parallel in that circuit - so it's probably induced voltage from the standing (well, actually alternating) magnetic field. I hadn't thought of that, and should have, since I just a couple of weeks ago explained to a sales guy in Best Buy about the alternating/standing magnetic field generated by AC wiring and why that field meant it was wise not to run data cables parallel to AC wiring.
