two questions on finishing
Rick Snyder
At what point in time did spraying a finish on furniture by the "makers" start.
Are there brush on toners available, and what brand would they be, also are dye stains considered toners.
Thank You,
Rick
Rick Snyder
Thank You,
Rick
Re: two questions on finishing
I have been spraying finish over forty years. It did not seem like a new art then.
Some people think making the piece is half the work and finishing it is the other half. My problem is that I want it to be more like 80/20 or even 90/10 and that does not lead to good finishes.
Howard Acheson
It began in 1892. Google and Wiki are your friends for questions like this.
Toners are applied over an undercoat of some type. The undercoat can be a colored stain or paint. Generally, the toner is a tinted lacquer that is sprayed on.
Jerry Gibbs
I was taught that toner is colored film finish. If you can brush on the film otherwise, you can brush it on colored. That said, toner is generally used to change the color on the underlying piece in a subtle manner. Misting with a spray gun is preferred. I would find it hard to do with a brush for poly and would be unable to do it with lacquer or shellac. The advantage of spraying is that you can mist on light coats and sneak up on the shade you want. Jerry
Toners vs. Stains
As mentioned, a toner is used to make subtle changes to the overall color of a piece as opposed to stains which penetrate the wood to change the base color of the material. This is different still from "glazing" or "pickling" with apply dark or light pigments to pores and detail lines to increase contrast.
All stains have a bit of dye in them. Pure dye stains provide a more even color to the wood because the very finely ground colorants don't aggregate in pores and grain. Dyes, however, can be used to make toners by addition to a film finish like shellac or lacquer. The hard part of toning is avoiding lap marks which double the color charge and have to be sanded out. This is why toners are usually sprayed. I make toner out of metalized dye concentrates in alcohol that are then added, drop-by-drop to 1 lb cut dewaxed shellac. I apply them very lightly with a mini gun that's top fed using 10-15 psi, a wide fan, and the material dialed back to, as mentioned, sneak up on the desired color.
