Burning Ash
Burning Ash
Burning Ash
Bill Marr
Making a lift lid box with ash. When I cut the miters on the tablesaw they invariably burn. I have cleaned the blade and they still burn. Does anyone have any ideas about what is causing this or how to prevent it. Thanks.
Re: Burning Ash
Re: Burning Ash
John in NM
Get the blade sharpened? I notice it a lot more on the CSMS, but then it's cross cutting all the time.
Re: Burning Ash
let me guess......
......you are using a Forest blade, or something similar that has minimal side clearance.
The cause is the sides of the teeth rubbing on the wood. More clearance or more sharp is the solution.......unless.
There is an arcane table saw alignment that causes the blade alignment to the miter slot to change as the blade is tilted.
Re: Burning Ash
Re: Burning Ash
Bill Howatt
Normally this is a problem often associated with the blade not parallel with a fence when making rip cuts. The dull blade is certainly a possibility but feed rate can also be a problem; you should never pause during the cut. Other causes can be reactive wood that causes the kerf to close or a twisting action when forces are altered during cutting.
Bill
Re: Burning Ash
answer depends on the type of miter cut
Bruce, a MN Galoot
I'll bet you're using a contractor saw.
If you're talking about a miter cut with the blade vertical, then the arbor/blade needs to be set parallel to the miter slots.
OTOH, if you're cutting with the blade tilted, then the arbor needs to be shimmed down, usually at the back. As the wood passes across the back of the blade, it's rubbing against the teeth, when there should be very little, if any, contact.
Re: Burning Ash
Re: Burning Ash
Ralph Lipeles
I also sometimes get burning when cutting hardwoods. I believe that it's caused by a blade that is not sharp enough. However, I don't always have a sharp blade at hand. So, my solution is to cut the piece slightly oversize and then take a very light cut to bring the piece to size. The light finishing cut does not burn as a heavier cut would.
Ralph Lipeles
Re: Burning Ash
Re: Burning Ash
John in NM
Well, from what I read of the OP, sounds like a dull blade to me :D
But you are quite correct, all that other stuff causes burning as well.
Re: Burning Ash
Re: Burning Ash
Bill Marr
I guess I should have been more specific in my setup description. Yes, I'm using a Craftsman contractors saw. The blade is an Oldham Signature carbide ATB tilted at a 45.
I appreciate your help and although the blade doesn't burn much on cross or rips at a 90, I wll get the blade sharpened and try again. Thanks.
Bill
Re: Burning Ash
Read this article *LINK*
Back in '95, we brought in an article about the "arcane adjustment" Bill Tindall mentioned above. We called it "Supertune Your Tablesaw", and it really is the reason you are getting this problem. Few saws -- either cabinet saws or contractor saws -- come perfectly tuned for bevel cutting, where the slightest table tilt backward or forward will compromise the alignment of the teeth when the blade is not at 90º to the tabletop. Sharp blades are important, but this is a little-known tune up that can solve your problem.
Ellis Walentine, Host
Re: Burning Ash
How to tell if the blade is dull
Repeated from my memory(such as it is) as told by technician at Misenheimer Saw Works.
The first sign of a dull carbide blade is that it will splinter wood fibers where the blade exits the kerf. A sharp blade will leave a clean exit. That said, for general work I use a blade well beyond this point.
Re: Burning Ash
Re: Burning Ash - Eureka!!!
Bill Marr
I put on a new blade, no burn marks! Thank you all for taking the time to help me out.
Bill
Re: Burning Ash
Re: How to tell if the blade is dull
Bill Marr
Thank you Sir. Good words to cut by!
Bill
Re: Burning Ash
Re: Read this article
Bill Marr
Ellis,
I read both articles and the chances that my trunion(s) are out of alignment are probably better than 50/50 as I have been having difficulty getting my miters to be exact, even if they are burned. At the moment I don't have a caliper for measuring to 1000th of an inch but it looks like I may need to find one. The TS aligner and the infinity look like good products but I would probably be inclined to follow the super tune method. I appreciate your advice. It's been very helpful.
Bill
Re: Burning Ash
dull or dirty?
If it had pitch built up on it it may cause burning. Warped is another possibility.
Re: Burning Ash
Re: dull or dirty?
Jesse Cloud
My sharpener once told me that about 50 percent of the blades hobbyists bring to him really just need to be cleaned, rather than sharpened.
Re: Burning Ash
Re: dull or dirty?
Bill Marr
Thanks Bill. Unfortunately, the burn happened if when it was just cleaned. Great idea. I appreciate your help.
Bill
Re: Burning Ash
Re: dull or dirty?
Bill Marr
Thanks Jesse. Unfortunately, the blade was cleaned just before cutting the miters. Great idea. Thanks.
Bill
Re: Burning Ash
Re: answer depends on the type of miter cut
Bill Marr
Thanks Bruce- how do you "shim down " the arbor, from the back?
Bill
Re: Burning Ash
John in NM
Most of us run them well past that point!
I agree though, after hearing more about the circumstances, that it's more likely to be alignment than blade condition. I read "miter" and thought of a 45 with the blade plumb and the miter gauge set at 45.
Re: Burning Ash
It can be checked with a feeler gauge. My powermatic contractors saw had that exact problem. Checking a d tuning the blade at 45 degrees solved the problem. Contractors saws are a pain in the but to fine adjust but its worth the hassle
