OT Repairing fiberglass canoe
A friend bought an old fiberglass canoe that is painted (?) Red. On closer examination it has the outer coat chipping off and you can see the glass mat.
How do you repair this? I suspect that the harder we look and the more we pick, the worse it will get.
Re: OT Repairing fiberglass canoe
Re: OT Repairing fiberglass canoe *LINK*
Bruce, a MN Galoot
I suspect the answer will involve lots of sanding, maybe patching and a gel coat or two. I've done it on my own cedar strip canoe and some other stuff I've made, but I've never repaired a solid fiberglass anything. I know for sure you can find the answer here:
West System Fiberglass Repair
Here is another helpful source. *LINK*
Keith Newton
Barry, it could be as simple as picking or scraping anything that will chip off, then sanding. Bondo can take care of big blemishes, and more sanding, then sealing, and painting.
West Marine has some very good help pages for anything related to boats. Here is a link.
http://www.westmarine.com/webapp/wcs/stores/servlet/WestAdvisorView?langId=-1&storeId=11151&catalogId=10001&page=Gelcoat-Repairs#.UtFwG_1978s
Dick Hines
Dick Hines
The next time you are in Farmville stop by the canoe shop. I bet they can tell you how to fix it.
Tom
I bought a second hand kayak around 1972, and I fixed the holes in the gel coat by pouring in small amounts of fiberglass resin, then sanding them flush. This left a few small blackish spots since I didn't attempt to colour match them. Still using the boat.
Today I would use epoxy, particularly if the holes were not undercut bubbles like mine were, as the epoxy will adhere better.
Take some time to examine the surface to assure yourself that the whole surface is not separating. Not all canoes are worth fixing, and there have over time been a lot of problems with early glass work. If you want to paint the boat, probably a linear poly like awlgrip would be worth a look. These normally require a lot of prep, and even multiple undercoatings with crazy expensive products, but something you can find some products that aren't too expensive. I have used the stuff directly over epoxy, and directly over interlux epoxy primer.
We have been using Behr exterior super white base on a lot of our boats, with satisfaction. It is not tough like the real paints, but it is cheap, lasts well and when it scratches, is easily fixed. I have been quite interested in trying their new nano tech paint, that they do not recommend for exterior, or at least the early stuff I saw was not recommended for that. Usually that is because they don't want people to use it over raw wood, since that stuff moves so much some of the harder paints will fail. But over glass it would probably work. You can do your own tests by trying something out, then after it dries thoroughly see if various tough tapes will rip it off.
