How thick are mattresses?
Jim in N. Va
I'm about to make a full size (double) bed for my daughter who will be moving to a new city in a few months. This will be the fourth bed I've made. For the first three (made quite a few years ago), I had the mattresses before I designed/made the bed. This time, that won't be possible.
There seems to be quite a range in mattress thickness these days. Is one thickness more "standard" than the others? What thickness would you allow for so that the headboard is neither too low nor too high?
Re: How thick are mattresses?
Yonak
Jim, if it were me, I'd design for a thinner mattress rather than a thick one. I'd think it would be better for the mattress to cover some of the bottom of the headboard rather than the bottom of the headboard too high above the top of the mattress.
That's a loaded question
David Yoho
That's a tough question to have an answer for these days. Not only do you need to know how thick the mattress is but also the box spring. Making this more difficult, it seems box spring units come in some different thicknesses too.
Last year my wife and I went to a furniture store in Aylett, VA that was closing after 50 years in business. I was planning to build us a new bed to replace our 30-year-old waterbed. As we looked around the store I came across a bed I knew my wife would like that was 70% off. She loved it, it was solid cherry and came with a large dresser to match, which we didn't need, and the cost was still less than I could buy the wood for a new bed. So we bought it.
Then we headed to our local The Original Mattress Factory to pick out a new box spring and mattress. The mattress we bought was 15-inches thick and the box spring was the average thickness. I began thinking about how high up on the headboard the top of the combo would fall. I was so worried about it I drove back out to the furniture store to measure. The combo they had on the display came to 15-inches and was just right. Any more would have covered up most of the Queen Anne style headboard and our combo was a little over 20!!
The mattress store also sold a thinner box spring than we ordered but it was still thicker than would work and we weren't going to change the mattress choice. My solution was to cancel the box spring and instead ordered a bunky board. The bunky board still offers enough support for the mattress but adds almost no height to the combo. Once everything was set up, it looked fine.
Whenever I'm asked to build a bed for someone the first thing I ask is how high (or thick) their mattress and box spring are together. If they are planning to buy new but haven't yet picked out anything, I tell them for me to build the proper bed frame to fit they'll need to select what they plan to use. Then and only then, with the measurement for total height, will I quote a price or prepare a plan. There are just too many mattresses of different thicknesses today to hazard a guess and build something that doesn't fit properly.
Re: That's a loaded question
Jim in N. Va
David,
Your story exactly illustrates my concern about building a bed w/o the mattress first. I'm not worry about the box spring, because I do not use those. The mattress will lay on a platform of closely spaced slats.
Two of the beds I built previously were twins and I used bunky boards. I did not realize until I read your response that bunky boards even came in larger sizes.
Thanks again. I am thinking I'm going to have my daughter go mattress "shopping" now and pick out what she wants, even though she won't buy it until she's settled in her new city.
Jim
John McGaw
Can't speak for full size but queen size can get anywhere up to 16"-18", not counting the box spring. I built my queen bed before knowing how thick modern mattresses had grown and totally blew it even though mine was only 14". With the box spring in place it was high enough to get into nose-bleed range and a fall to the hardwood floor could have been deadly. I eventually ditched the box spring and changed it to a platform style. I'd advise that your daughter pick out a particular brand and model mattress before you build, even if she doesn't buy it until she reaches her destination.
don stephan
Some flexibility can be allowed by planning to use angles screwed to the inside surface of the rails. It's likely angles can be obtained in different lengths, although not sure the drilled screw hole patterns will be the same. One person I know uses steel U channel between four pair of angles for an extremely rigid system.
Jim in N. Va
Don, thanks for the suggestion. That would work if I was planning on using a box spring. But I think box springs are a waste of space and $. I'm planning on having the mattress sit on a platform of closely spaced slats and the height of those cannot be easily adjusted.
