Kimono Cabinet
Kimono Cabinet
Kimono Cabinet
charlie belden
Twelve years ago, two years after I got into woodworking, I had an idea for I don't know what the piece of furniture would be called, but I've always thought of it as a Kimono Cabinet. I did some basic 2D CAD drawings of the idea and then with a little PhotoShop wizardry and some digital images of some interesting boards I'd acquired did a Real Wood looking version of the idea. I used that image for the "splash screen" of my woodworking web site.
Here's the original idea
Having a few year's experience with Google's free 3D app, SketchUp, mainly using it for simple one axis turning design as well as multi axis turning design, I've started on a virtual 3D full scale virtual model of the Kimono Cabinet idea.
I began with 2D - the "boxes" - at full size. Next I divided up the boxes for shelves and drawers and cabinet doors - still in 2D. When I had a look I liked, and that would be practical - reasonable sized graduated drawers, shelves and "dust panels", I started "extruding" the boxes to the depth of the cabinets I wanted. Next, I did the shelves and "dust panels" then did the drawers, the fronts of the main cabinet drawers are "overlaid" with 1/8" between them. Next I added circular the drawer pulls, which I envision turning so there's an inside lip in their openings - think "beaded rim". I then put in the cabinet doors very generically, will come up with some details later. Still need to come up with a nicer base for this thing but I did something just to see the basic size.
Once I've done the basics I'll fine tune things a bit more then start working out the joinery.
I've got what I think will be the perfect wood for this piece - quarter sawn english sycamore (it's ACTUALLY a maple) that has some nice horizontal striped figure that reminds me of the look of silk, and if I "pop" the grain, it'll give the piece a subtle 3D shimmering look. I got a deal on 200 bf of this stuff, about half with the nice figure. Have had it for maybe three years, waiting for the right project to come along.
Apologies for the odd colors but it makes keeping track of things a LOT easier.
Looks like my lathe's not going to be used much for a while - and I'm gonna HAVE TO clear off my combination machine (Robland X-31, work bench and layout/assembly bench - and finally get around to installing the cyclone dust collectors I got from Bill Pentz, probably four years ago ; )
I my Das Bench project ("real" woodworking bench) is any indicator of how long before this piece gets made, this could be a 6 month elapsed time endeavor.
Comments, questions and suggestions welcomes.
Re: Kimono Cabinet
Re: Kimono Cabinet
I see the kimono reference. The term I remember from my gardening days is agacki (spelled wrong I'm sure) that translates to "sleeve", as in the billowing sleeve of a kimono. In gardening, as I recall it used for the short extension of a fence that turns a corner or hides something from view.
I tried to look up some references but my internet is running so slow I think a sneaker net would be faster.
Interesting cabinet. Interesting project. My engineering brain wants to know if you will make it so it is easy to dissemble for moving.
Re: Kimono Cabinet
Re: Kimono Cabinet
Keith Newton
Nice, The only thing I can't tell, is if the two sleeve cabinets are the same depth front to back. I think I would like to see them back about 2" maybe.
As for Barry's question about break-down for moving, it should be easy enough to break it into components. But I was thinking that you might also use a french cleat along the back to hang the sides on the wall. It sure would make it more stable.
Re: Kimono Cabinet
Re: Kimono Cabinet
Phil
FWIW: I like it. I particularly like the lines of the base. Would there be some way to replicate those lines in the upper portion of the assembly, perhaps on the outboard cabinets?
Re: Kimono Cabinet
Re: Kimono Cabinet
charlie belden
> Barry asked
That's the intent. As is, it's five boxes - 2 boxes for the "sleeves", one for the "body" and two
narrow ones for between the sleeves and the body (am thinking of a tall narrow "drawer",
but with the "bottom" in the middle for hanging necklaces, earrings, bracelets etc. on either
side of the vertical "bottom").
I think the "body" box should probably be broken up into two boxes, one for the drawer unit
and one for the shelved cabinet unit above it. The shelved unit would have to be narrower and
shallower too register it to the top of the drawer unit. That would make it easier to set up and
take down for moving. Coming up with a transition that looks good will be a design challenge
though. Maybe a stepped back on top cove molding might work.
> and Keith suggested
Excellent idea Keith! Having set back planes would make the central cabinet the primary focus
of attention, popping it out - subtly - if that makes any sense.
It's the drawers that dicate the central cabinet's depth. The other "boxes" have fewer
constraints so there's much more flexibility for their depths.
If I go with a drawer unit and shelved cabinet above it, the shelved cabinet would have
to be stepped back anyway. So that would mean two front planes for the central part
of the piece. Stepping back the "sleeves" would add another plane to the piece.
Were the outside "cabinets" be hung on cleats attached to the wall, replacing the idea of shelves
and drawers with space in the doors as well as inside the shallow cabinet could be interesting,
There could be room to hang jewelry - necklaces, earrings, pentands, AND some narrow shelves
for small jewelry boxes, etc. That would effectively double the out of sight storage surfaces without
increasing the footprint of the piece. Hmmmmmm . . .
One of the many nice things about making full scale virtual 3D models of ideas is that you can
copy a model, quickly make changes to it - while still keeping the previous iteration - and it's self
documenting of the evolution of an idea from concept through finished plans. Sort of like a
word processor fir fyrbityre design.
Re: Kimono Cabinet
A few more thoughts have come to mind.
Keith Newton
Since you are still playing with things, I think I would consider lowering the tops of the two arm, or sleeves a little bit. This would develop more of a shoulder look for the torso, and step back on the lower part under the belt, or sash line.
And I'm sure at some point, when you get back to turning, you can find something to display on top of that mid-section, but I don't expect that will be easy. Well, not for me anyway.
And one other little fun thing I would think about. On the ends, just under the top, I would try to come up with some little discreet finger/fastener capable of holding something like a tie, scarf, flower, note, or glove, not on a permanent basis, but that could be a fun little reminder for whomever ends up living with this piece. They can send subtle little reminders of things of the day, coming up, or the past to their significant other.
Just random thoughts, looking forward to seeing the finished piece.
Re: Kimono Cabinet
Re: Kimono Cabinet
charlie belden
Phil:
The lines are to imply that the kimono is wrapped around the body rather than slipped onto it (think double breasted suit),
The circles on the drawer fronts, which are graduated and act as drawer pulls, each follow a curve implying either a fold or
another layer of cloth. The liness shown in the lower illustration to the right were merely used to layout where the pulls
should go. For the top drawer, which is small, they'd be 4 or 5" apart so the drawer could be opened with one hand. As
the drawers get larger, pulling them open from the middle could cause them to bind, so the spacing is such that two hands
are needed to open them.
As for working in lines on the sleeves, that's a possibility. But I plan on using quarter sawn "english sycamore" (actually a
maple, not a sycamore) that has a "fiddle back" / "horizontal stripes" figure to it that reminds me of the look of silk. That
horizontal figure for all the front faces will provide some visual continuity to the look of the piece.
Have a lot of design decisions to make once the basic model, with it's actual dimensions has been worked out. Need to
decide if the drawers in the bottom of the sleeves should be outside the cabinet doors or ihside the cabinet doors. The forner
would provide a more kimono silk fabric look, but make the drawers less accessible, and shallower,
Re: Kimono Cabinet
Re: Kimono Cabinet
It seems to me that this would be very "formidable" and perhaps especially if you were to view it from the side. The idea of recessing the sleeves back a bit seems good. How about using curved doors for the front of the center section? That section could bulge slightly over the lower section.
And please don't turn a big spherical hollow form and set it on the the center section. Putting a jack-o-lantern on it would completely destroy the effect.
Re: Kimono Cabinet
Kimono Cabinet v 3.0, 3.1, 3.2
charlie belden
Got in to WAY to much detail in v 1.0. Intended to work out just the box sizes - in 3D, then got carried away with drawers and shelves, dust panels and doors. So - back to basics and using the great suggestions provided.
Made the center box into 3 boces so now it's 7 boxes, with 1/2" cove molding for alignment and transitions between some of the boxes (the molding profile will likely change - but for now . . .) The center drawer box will probably be a little taller in time.
Here's a second cut at stepped backed"sleeves" and break up the central box Kimon Cabinet L to R - v 3.0, 3.1 an 3.2. v 3.2 has the sleeves boxes only 8" deep, split half for the cabinet and half for the doors. So flatter stuff like necklaces and other jewelry can be hung on the back of the shallow cabinet as well as inside the doors.
As you can see, coopering the doors of the top central unit would be a bit tricky, but curving the drawers below would be way beyond my knowledge and skills.
Re: Kimono Cabinet
curved drawers
They are not at all hard to do given knowledge of a couple of aids in doing them. (I had this help on mine)They do take more time, but assembly is no different than a regularly drawers. One secret is to leave the back flat until the drawer dovetails are cut. Veneering the front is easy with a bag and vacuum, again with the back flat. The dividers are left wide and scribed off what ever shape the drawer winds up. A bit of cock beading hides the minor errors.
If you want to consider curved drawers I can help with the details. Bottom line is that it takes longer but isn't harder.
Doors are another issue. They must be done first and a cabinet fitted tothem. Krenov worked out the tricks. Tedious.
Re: Kimono Cabinet
Re: curved drawers (and doors)?
charlie belden
Bill:
I appreciate your offer of help with curved drawer fronts. For a simpler piece, curved drawer fronts would be a nice feature that wouldn't require that much more work - or skills. But with this idea, there are too many "boxes" to figure out how to get them all to work together to create a coherent whole.
There are several "challenges" were I to go with curved drawer fronts.
First, because there are two other "boxes" above the drawer "box" I want to have transitions between them, in part to register the stacked boxes to planned locations / positions. I'm thinking some type of coved or Ogee molding could work for the transitions. Curving molding can be done, but mitering the ends of curved molding - to match straight molding of the same profile - can be tricky.
If curved drawer fronts were to be used, the cabinet doors should probably also be curved. Coopered doors I can, and have done. But they look best with knife hinges. Knife hinges present additional challenges, both in terms of how their cabinet is made as well as their installation. You have almost NO adjustment options with knife hinges - get it right - or - maybe have to make a new top and bottom for the cabinet they are for. Piano hinging coopered doors is an option, but installing piano hinges correctly is another challenge - again - with very little margin of error.
I think the following may illustrate some of the design challenges to address if curves are made part of this Kimono Cabinet idea.
Long way to go, and plenty of options to explore before getting to how things will be joined, let alone stock selection, grain matching, stock prep, parts making, joint cutting, . . .
Re: Kimono Cabinet
that left sketch looks sooooo good.
Looks so good I would like to hug it. Gallery Grade design. The right one, no.
I appreciate the hinge concern. I thought knife hinge installation was going to be difficult on the Krenov style cabinet I built, but it turned out trivial. Krenov lessened the stress with his case joinery approach. With the case temporarily "dry" doweled together all that fiddly fitting becomes easier because pieces can be taken apart to work on to fit or install hinges.
Re: Kimono Cabinet
one mo' variation
Try it with the arms fading back left and right. If you have them lets say eight inches front to back now try drawing them with the cabinet side eight inches and the outer sides four or five inches. I'm the guy that suggested making them shallower. Perhaps there is a theme in my suggestions.
Re: Kimono Cabinet
Re: one mo' variation
charlie belden
Barry:
Curved drawer fronts I can probably do - as add ons to drawer boxes. I have a bandsaw with the resaw capacity and a long outboard pneumatic drum sander add on to my regular drum sander (Delta if I recall correctly) - to take out saw marks, and scrapers to smooth things out.
Coopered doors I HAVE done - successfully - though installing knife hinges is something I need to work out.
Tapering the "sleeve" cabinets - 8" wide towards the center cabinet and drawers unit, 4-5" wide on the end away from the center unit wouldn't pose that much of a problem. The problem comes in when you get to the shelves and or drawers inside a tapered laterally, curved doors cabinet.
I HAVE done a few curved drawers, here's one for example, from one of my wall hanging tool cabinets. A #7 plane is stored behind it which explains the cutouts.
But aside from the construction / parts fabrication issues, there's a fine line between Kimono and Airplane fuselage and wing I THINK one of the right two images is what you were suggesting.
