A Fun Little Project
Rod Peterson—Ormond Beach, FL
I've been dissatisfied with the tool post clamp on the banjo of my Delta 46-701 lathe for some time. It's basically a 5/8" headless bolt with a tommy bar for leverage. The nature of the bar gets it in the way more than it helps.
The other day, I noticed Tommy MacDonald tightening the clamp on his Powermatic mortiser in an episode of PBS' Rough Cut, and noticed a flat blade in the shaft of the clamp which is an ever so much more elegant application. I thought I'd investigate crafting one.
Above is a view of the old and the new—OEM clamp on the left and my new one on the right. But to get to this result required some work. First I found a bolt. It turns out to be a standard SAE thread bolt. I took it home, hacksawed the head off and hacksawed half of the foot off, and then contemplated the slot.
I am not a machinist (although I have a survey understanding of a lot of the processes), but it didn't take a lot of thinking to realize that machining a slot in the end of the bolt was going to require more than a hacksaw and a file. So, I found a local machine shop who milled a slot for me.
On the way home I had stopped at the local hardware store and picked up a 1/8" roll pin to serve as a pivot. Then I hacksawed some flat stock to make whatever that wing thing might be called. Some time at the grinder and a couple of holes later I had the final result below:
Here is the new clamp attached to the banjo. Preliminary fumbling seems to be promising. It'll be a few days before I roll the lathe out of the shop for a test spin. Already I like it, though. Oh, a newly acquired 4" tool rest showed up today, too, so I get to try out all kinds of stuff.
Hey, not all projects are masterpieces…
Rod
Re: A Fun Little Project
Bob Entwisle in NJ
Hi Rod,
Very timely!
I recently hauled my 46-701 up off the floor and bolted it down to the bench to fool around with and observed the same distaste at the function of the tool post clamp.
I hope you won't mind me copying your new clamp bolt design.
Bob in NJ
That'll do nicely Rod !
By all means, Bob
Although it's hardly an original design on my part. I just adapted what's probably a pretty old idea to begin with.
Also, although I used a machine shop for slotting the bolt, if I had a cross slide vise, I probably could have milled it with my drill press. But, as Harry Callahan said in Magnum Force, "a man's got to know his limitations."
The only thing I'd like now, is a method for blackening the new clamp to look more like the old one. I hate shiny new stuff…
Blackening
Dave Bair
Try some instant gun-blue. Birchwood Casey makes several versions for the home user.
making black
I made a rock trimmer product once in cooperation with a machinist. I did the blackening. Just baked the metal at some high temperature and it formed a black oxide coating that was rust resistant. Can not remember the temperature. I would try 550 F in the oven.
Won't work
RobCarr
Cold bluing won't work on anything that's plated - it requires plain carbon steel.
Re: Thought about a cold blue
john Veerkamp
dip the exposed parts into sulfuric acid. Found in many high power drain cleaners. The modern electro plating is so thin it only takes a few minutes to remove it. I wouldn't remove the plating from the threads as this may decrease the size enough to prevent good grip.
