***Special Guest Chat -- Michael Dresdner***
Re: ***Special Guest Chat -- Michael Dresdner***
Michael Dresdner Chat Transcript *LINK*
Bob Entwisle in NJ
In case you missed it.
Michael Dresdner 01-09-2013 Chat Transcript
suggestion
this transcript has abbreviations for stuff that most are not going to know what is being described- "MIK", "EB" etc. I am familiar with solvents and I don't know what some of these refer to. I could help edit the transcript to translate some of them, but not all.
Re: suggestion
William Duffield
I figured them out with Google's help, typing in the acronym followed by "solvent."
EB - Ethylene Glycol Monobutyll Ether or 2-Butoxyethanol http://en.wikipedia.org/wiki/2-Butoxyethanol
MAK - Methyl n-Amyl Ketone
MIBK - Methyl Isobutyl Ketone
http://en.wikipedia.org/wiki/Methyl_isobutyl_ketone
Michael notes that these may be used to modify a spraying lacquer into a brushing or padding lacquer.
There are some obvious acronyms that are not defined at first use:
PG - Propylene Glycol
BLO - Boiled Linseed Oil
CA - cyanoacrylate
NYC - New York City
CFL - Compact Fluorescent Light
SWP - Sherwin Williams Paints
CPS - no idea, may be a typo
OSI - This is a Scientific Wild Ass Guess (SWAG). It may be OSi Specialties, now part of General Electric, maker of silicone surfactants. Michael will have to answer this one, as well as the specific chemical he recommends for slowing down shellac.*
FWW - Fine Woodworking
WWJ - Woodworker's Journal
AW - American Woodworker
CO - Colorado
CT - Connecticut
I may have missed some.
When I was doing technical writing, the convention we used was to put the acronym in parentheses immediately following the first use and then collect all the acronyms in a glossary at the end of the document (just in case you missed the first use in a long document).
*Behlens uses isobutanol in their Behcol shellac solvent product.
shellac and surface tension
I didn't understand the whole shellac discussion. Some clarification of the problem would have been helpful. I have brushed, padded, polished and sprayed shellac and didn't discover a surface tension problem. If I had I would have used isopropanol to change it. Isopropanol is a dandy solvent to bridge between greasy stuff and watery stuff.
PG?
I thought propylene glycol too but the 1,2- isomer boils at 190 C. I would think that Hell would freeze over before it evaporated from the film to allow it to harden. It is a good solvent for treating sheep in ketosis.
Re: PG?
William Duffield
Maybe, Michael will have a better explanation for us?
