Samantha's dresser Part 1
Samantha’s dresser Part 1
There was some interest expressed in the details of this project. Over the next few months as I build it I will post details of how it is built. These details may be of value to those that have not settled on a way to build case pieces. For those that have other approaches it will be an opportunity to compare and contrast.
When I began to build furniture for the house, case pieces- boxes with drawers and doors- were a common need. There are dozens of ways to build them. I never found a good book that provided a road map. A class in the Mack Headley and Sons shop did. Their approach, common to Period furniture from the Shenandoah valley, is relatively quick, robust, reliable, and easy to execute with mostly power tools. I will note where I deviate from their approach, and why.
Choosing the lumber for panels
I like to make sides and top from one thick plank resawed and book matched, or from one board, cut in the middle, and folded back on itself. The edges of wide boards are invariably rift grain and when folded back on itself a board can usually be nicely matched to yield an attractive pattern. In this picture I am diddling with the two pieces, testing orientations to get the best effect.
Next, glue them together. I can not over emphasize the need to have everything ready to go. A dry fit of the pieces is the way to ensure you are ready to glue. Note the scrap pieces between clamps and panel edge. There is more glue squeeze out on this panel than I consider ideal. It is most convenient to remove the panel from the clamps and scrape the glue off while the glue is still rubbery. If the glue is hard be careful removing it. Shearing it off can lift pieces of wood under the glue drops and this is very bad. I shave dry glue off with a cheap block plane reserved for this abuse.
I am very fond of the clamps shown. They are used commercially. Lee Valley now sells them or in bulk you can buy direct from factory. Our club has bought hundreds of them for members.
There are lots of ways of spreading glue. There are several goals to be achieved. Most critically, both edge faces need to be wet with glue to make a bond. Also critical, the surface of the glue must not begin to dry before joint assembly. And, it is desirable to not have gobs of glue squeezing out to be cleaned up later. To get both surfaces wet, quickly, to avoid drying in the winter low humidity shop environment, I deposit a thin layer of glue by running a thin track of glue from the bottle down each outside edge of one board and down the middle of the other(see picture). Then I push the boards together lightly and wiggle them to transfer glue between the surfaces. I raise the edge to see that I have glue largely on both surfaces and then proceed to tighten the clamps, starting in the center and working my way to each end while adjusting the alignment. Finally, I snug each clamp. After a minute or two I snug the clamps again. Sufficient pressure must be applied to squeeze out all the glue that can be squeezed out to yield a gap-free joint. The glue line in a well made joint can not be seen.
