I have several sheets of marble around 20-30 mm thick that I'd like to use for some projects. Some are simple--just a rectangle with smooth edges and a semi-polished face. There's also some sort of small table lurking somewhere. A demilune, maybe.
Am I limited to taking the material to someone who works marble, or are there options that involve tools that I, as a compulsive tool-accumulating woodworker, might have or might now have an excuse to get?
For straight line cutting, an inexpensive diamond blade/wet saw will make short work of the marble. I paid $45 for one at Harbor Freight a few years back and used it for cutting travertine and porcelain floor tiles. It worked well for me, as long as I went slow in cutting. I used the included "fence," but when one end of the locking tab broke (my fault - tried to force it down with a sliver of tile under it), I used a simple straight edge clamped down with a pair of vise grips.
If you cut slowly, the edge on the marble will be semi-smooth like you want.
You can get pretty much the same saw at Home Depot or Lowes for about the same money. You can spend a lot more if you want a professional "use it every day" model, but the pro model will only work faster, not necessarily faster.
Roughly the same as mild steel. Historically it's been sculpted with tool steel rasps and chisels, though they wear out quickly.
You could easily cut it with a carbide abrasive jig saw blade and smooth with SiC sandpaper. Marble is one of the more crumbly rocks I've dealt with, but it epoxies nicely so that is more of an annoyance than a serious problem. I like to use opaque epoxy tinted to match the stone, but even 5 minute stuff will work fine.
You can also go the wet saw/diamond route as Mark suggests. Then you are set if you want to do some granite too
As one who has worked with marble before I can say that the diamond wet saws will cut it but feed slowly because it does tend to break rather easily. Also, a set of diamond tipped dremel bits (even a cheap set from Harbor Freight) will work well for carving or cutting shaped pieces if that interests you.
As for polishing, start with 320 grit wet/dry sandpaper and plenty of water. You can work it by hand or buy one of these: http://www.harborfreight.com/jitterbug-orbital-air-sander-90115.html.
DO NOT use an electric tool for the obvious reason.
Work thru the grits up to at least 2000 and then go to rubbing compound and polishing compound on a polishing wheel.
Be sure when you are finished with the sanding tool to take it apart, blow dry it, and oil it well so it does not rust.
I am presently working on a jewelry box inlay of sodalite, a blue stone with white crystalline marbling. It is a medium hard mineral, so it works well with the afore mentioned tools. Marble has a hardness of 3-4, so it is softer than sodalite.
Maybe I'd be as well off to just take it to someone, since the table top will need some sort of edge treatment that is probably beyond my capabilities. I appreciate all the suggestions.
