OT Cleaning Plastic Eyeglass lenses?
I have Plastic lenses. IIRC they are supposed to have both anti scratch and anti glare coating. I only have one pair so I can't take them off to look at them closely. I am seeing stars or specks. If I gently run the tip of a fingernail over them I feel specs. It might be spray finish or sap of some other wood working crud. I clean them by running hot water over them and wiping on a clean cotton towel. Any other suggestions? I have not put solvents on them for fear of damage.
Re: OT Cleaning Plastic Eyeglass lenses?
Bob Entwisle in NJ
Hi Barry,
I use warm water and dish soap, like dawn. Maybe rubbing alcohol, but be careful.
And a pair of drugstore reading glasses helps me to see what it is i'm trying to clean off my regular glasses ;)
Bob in NJ
I can't decide....
if my scraping with the fingernail is removing crud or damaging the coating.
I will try the soap and maybe let them soak for a few minutes. If I get out today I may stop by an Eyeglass shop and let them look.
I would need two pairs of reading glasses to be able to see. >(
There is a great demonstration of polymer crazing where one bends a polycarbonate CD and adds a tiny drop of acetone to the bend. The CD explodes into shards. Don't add solvent to plastic lens.
Re: I can't decide....
Ralph Lipeles
My eye doctor told me years ago that if the drugstore reading glasses work for me, no headaches and clear vision, they were OK to use. Apparently the big difference is ground to shape VS cast. Obviously grinding is better but it runs about 15 times more. Try the cheapies. They may work for you.
Ralph Lipeles
Re: Buy a second pair *LINK*
Stuart Johnson
I've been buying my glasses from Zenni Optical for several years now. Good glasses at a very reasonable price. FWIW, my eye doctor has no objection to quality.
Zenni Optical
Be careful what you use
Lee Schierer in McKean, PA
You don't want to use any cleaner that has ammonia in it as it will remove the coatings. I don't think alcohol is good for the coating either. I use Zeis Lens cleaner. . I spray some on each lens, gently wipe it around with my finger and rinse under warm water.
Lee
Re: Be careful what you use
r payne
According to an optometrist I know, rubbing alcohol (not to exceed 70%) if safe to use on lenses (even coated ones). But not to use windex or similar window cleaners. Don't use paper products to wipe them off (or a cloth that may have sawdust in it). (She was always taking my glasses away from me to "properly" clean them.)
ron
james runchey
I've always cleaned my glasses by wiping with the damp towel after my shower. works for me.
Howard Norman
My eyeglass cleaning procedure is to coat with warm water in the bathroom sink, add one drop liquid Dial to each lens and using my thumb wash both sides of the lenses, rinse and dry with a hand towel. Works for me.
