Electrical question,3 way
Keith Newton
One of the old 3way dimmer switches in my office went out. I picked up one at HD, and started to install it. The configuration was different front the old ones, leaving me scratching my head. I guess the different colored screw will be either the power source, or out to the light, and the other two, the either or travelers.
I thought I would put my tester on it to be sure, but continuity doesn't show anything between any of them. Do these new dimmers need 120 V going through them to actually make the circuit? Or is imperative that the switch be hooked to ground, to function?
I built my office long before I built the studio, but had forgotten when I went looking for the breaker to kill this circuit. I found one listed as office lights, and threw it, but it was still hot, so lucky I tested it again. then I remembered it was probably in an old panel out in the shop, so just turned them all off. it was still hot, so I figured I would just go ahead and wire it hot. The energized wire was one of the travelers, so I figured I could wire the one in off position, then flip the other switch, and wire the other. That should work well enough.
Then I had the bright idea to pull the other switch out, and take the hot lead loose from it, which would be even safer. As I was pulling that switch out of the box, the darn thing just broke in half.
This day for me, has been rotten.
Re: Electrical question,3 way
I've only installed one
but on the one I installed, I was able to find continuity between the common and the "travelers." Are there just three screws, not counting the ground? If so, you should be able to find continuity. Did you have the dimmer set to full on?
I installed a 3-way dimmer with CFLs, but forgot to check whether the CFLs were dimmer-compatible. They're not. It doesn't much matter, because we don't use the dimmer. One evening, I went to turn the lights on, and they just flashed. Later, they worked fine; I'm thinking the dimmer is the problem. This modern electronical stuff can be a pain.
Thanks Bill.
Keith Newton
I found two more switches that I managed to use.
