Kids woodworking Christmas
GolfSteve in Calgary
Had some fun in the shop this Christmas:
First made some tree ornaments, cut from 1/8" birch plywood then painted fancy colours. The 7 year old used the scroll saw and traced the patterns using the one piece of old-fashioned carbon paper that I had the prescience to preserve several years ago. The 7 year old also drilled the decorative holes and the holes for the ribbon.
The best part for the kids is the painting.
The four year old only got to paint and measure. She loves measuring. She loves tape measures. Next year she's going to get her own tape measure for Christmas.
Over the holiday break I had planned to finish off some projects that have been hanging around, but the seven year old decided she wanted to build a table, so on a whim we built a kids table out of some maple pieces that weren't at the bottom of the wood pile.
Obviously a seven year old can't do this project on her own, so:
- I selected dimensioned the stock.
- We cut the joinery using Dominoes (we both held the tool while cutting the slots).
- We cut the leg tapers on the bandsaw (we both held the wood while cutting the taper).
- She sanded the pieces.
- She applied the glue and clamped it up.
- She mixed together just about ever colour of Transtint that I own into some lacquer to arrive at the final colour.
- I sprayed the table.
- She rubbed down the finish with some steel wool.
- She drilled the pilot holes for the screws with an egg-beater drill and installed the brackets to hold the top to the body.
Overall a nice project and it was nice to not obsess over every little detail like I usually do on my own projects.
Re: Kids woodworking Christmas
Hank Knight
Steve,
What a coincidence! I didn't see your post until after I posted mine. Working with your kids is great, isn't it? Even if, as in my case, they're 33 years old. You have great looking girls and a lot to look forward to!
Hank
Marty
Funny about Measuring Devices. My wife carries to this day. A Four Foot Tape her Grandfather gave to her while he was working at Philips Dodge Open Pit Copper Mine,in Ajo AZ. That was a L O N G time ago, back in the early 40's. Still readable on the side an inscription about the Mine. Takes it with her wherever we go. Never know when I might need to get a quick measurment. Get your Grandaughter a good one but small enough the she can carry with pride.
Bruce, a MN Galoot
A whole lotta years ago, a good friend gave me a little 3-ft tape measure as a gag gift. My wife always carries that in her purse. She knows that we both measure stuff wherever we go.
William Duffield
They sure look like they had fun.
You can still get carbon paper, or transfer paper, from Woodcraft, and probably other suppliers.
Woodcraft SKU codes are 143766 for 18"x 24" sheets and 152192 for 2' x 16' sheets.
Domino works great for making table top buttons and cutting the matching slots in the apron. Your table is too small to get the domino inside after it's assembled, so you'd have to cut the slots in the aprons before you assembled it. DAMHIKT!
You all work fast! Nice table.
I would like to do some scroll saw cut outs with granddaughter. Where did you get patterns?
My fist tool was the use of a scroll saw when I was about 7. It may well have been the start of my woodworking interest. Hope it works out the same for the girls.
Ditto
wife always has a measure available to get a dimension of something, but we measure bigger stuff. Her's is a 6 footer. If we anticipate antiques she carries a cloth tape for measuring on finished furniture surfaces.
Jack Guzman from Maine
Me too
My wife carries a bag everywhere she goes that has one of everything in it. It's funny watching her try to answer her cell phone,which is in that bag somewhere.
When I need to measure something she always comes through with her own tape measure.---Jack
Patterns
The patterns came from "Cute and Simple Woodworking" by Jennifer Burt that I borrowed from the library.
This was a fast project. The table was done in two days including the finishing. This was the first table I've built that does not have drawers and boy does that simplify things.
Table top buttons
I've used the domino to cut button slots before ... How do you use it to make the buttons?
Re: Table top buttons
William Duffield
You're going to give yourself a Homer slap when you realize how basic this is. :)
For starters, we will assume we are using 5mm Domino tenons. You have to start by cutting the slots the right height in the aprons. You don't use the Domino fence for any of this, so just stow it out of the way. Turn the table frame over, legs up on a FLAT work surface. I usually use my table saw. Pay attention to the wood movement of the table top when choosing the Domino width setting. Cut the slots indexing the base of the domino off the top of the table saw.
Start with a length of hardwood stock about 3/4" thick, and 7/8" or 1" wide. The exact height doesn't matter. The exact width doesn't matter either. Draw a series of lines across the top, about 1-1/4" apart. Lay the stick down on the work table and punch a mortise with the Domino in the side at each mark. Again, the 10 mm distance between the bottom of the Domino and the center of the mortise. No fence necessary. Glue a domino into each mortise. Put a countersink bit in your drill and drill a hole the stick and through the domino at each mark. The screw holes should be roughly centered on the width of the stock. If you use your drill press with a fence, you only need to set it once, about 1/2" from the edge of the stock. With your miter fence on your table saw (or your miter box, or chop saw, or RAS) cut the buttons apart, between the marks (and between the tenons). Note that if you use the 4 mm. tenons and a back saw in a miter and the narrow setting on the domino, you can get a couple more buttons out of each foot of stock.
Lay the table top upside down on the tablesaw, and position the frame on top of it. Pay attention to wood movement of the table top when screwing the buttons to the top.
William Duffield
Retail woodworking dealers carry a vast selection of books filled with scroll saw patterns. For example:
http://www.woodcraft.com/search2/search.aspx?query=scroll%20saw%20pattern
Thanks William. That is a simple method. The only downside I can see might occur when you need thin buttons to avoid conflict with a drawer.
William Duffield
On most projects, that shouldn't be a problem, as your top rail above the drawer and your kickers are usually about the same thickness as the buttons.
Of course, there's nothing wrong with a pocket screw fallback strategy.
If one is considering the Domino approach, there are a few small advantages. Small Domino tenons are very cheap. If you have a Domino joiner, you probably have a container with a few hundred of them right next to the joiner. You also should have plenty of FHWSs of the right length in the shop, and you would need them for whatever alternate method you would choose. You can make plenty of buttons in a hurry, and additional buttons beyond your immediate needs are very cheap. You don't need to make any critical measurements. Any extra buttons you make now will exactly fit the apron slots you cut with the Domino next week or next month. Laying out the center line for the joiner can be done with one setting on a pair of dividers, and walking them down the stock. Glue application is not critical, as the screw will hold the button together. You might think you need to to set one careful dimension on your miter fence stop block, but if you're smart, you would set the stop to the side of the tenon instead of to the end of the button block.
Ron in Sterling, CT
Bill,
I get free patterns from scrollsawworkshop.blogspot.com.
Ron
