ADVERTISE HERE - FREE TRIAL
Need Idea for no-mar tip on older brad nailer
kevin
I have a PC BN200 type 1 (not 200A, B, C). It did not come with a no-mar tip.
Any ideas on how to retro?
Other than this -- and the that it has no depth adjustment (other than air pressure), it's been a great tool.
Re: Need Idea for no-mar tip on older brad nailer
Plasti-dip?
Grant in Iowa
How about dipping it in something like plasti-dip? This is the stuff on the handles of pliers and such. Should be inexpensive and renewable. An added benefit would be it can be used for other things around the shop. I would do something like plugging the actual nail exit hole with a sliver of wood, dip/dry, repeat until desired thickness is achieved, then remove the nail hole plug.
Regards,
Grant in Iowa
Re: Plasti-dip?
kevin
I got an old can sitting in the shop. Time to see if it's still good -- been years.
Old Plasti-dip tends to turn into Plasti-solid. I've thrown away just one can, but it was enough to convince me that I should identify lots and lots of projects that need it allatonce before I buy another can.
You can get "liquid electrical tape" at your local hardware store. This uses a volatile solvent and sets up mighty fast. Not sure about its durability, but it would be easy to re-coat if the wear rate is high.
John McGaw
Would a layer or two of duct tape work? It fixes everything else in the known universe.
check here it is a nose-cushion
del schisler
http://www.ereplacementparts.com/nose-cushion-nomar-p-62538.html
This is what I was thinking....
Even though yours did not come with one, would one from a model that had one work?
Ralph Lipeles
I removed the tip and made a jig ( an alligator clip attached to a piece of copper wire) to hold the tip in place where I wanted it. I then cut a small piece of wax paper. Next, I squeezed some liquid rubber, from a tube, on to the tip, and used the jig to position the rubber covered tip where desired relative to the wax paper. After the liquid rubber dried I trimmed it with a utility knife and put it back on the tacker.
Re: check here it is a nose-cushion
kevin
Not Sure. Mine did not come with one. It's a BN200 type 1
If that nose tip is the same as the 200A, then I'd be good.
kevin
wonder if I just "waxed" the metal tip and then dipped or embedded it in a small lid filled with some material if that might work?
