Brad Nail Gun Reviews
don stephan
My brad nail gun died last spring and now I need one. Can anyone point me towards any recent comparison reviews so I'm not picking blind? Thanks in advance.
don stephan
Re: Brad Nail Gun Reviews
Bob Entwisle in NJ
Hi Don,
i don't recall any recent reviews, i've been happy with my PC BN200A, but I don't use it all that often, so don't know how it would stand up in a production situation. I've used a 'corless/airless' Paslode a few times and it's great for reno / jobsite work, no need to bother with compressor and such, but i don't think it would be that good in a shop environment where you have air readily available.
PWW reviewed the GREX a couple years ago:
<http://www.popularwoodworking.com/tools/tool-review-grexs-top-shelf-brad-nailer>
And I found this while searching for reviews:
<http://toolmonger.com/2010/10/07/hands-on-18ga-pneumatic-nailer-comparison/>
Hope this helps,
Bob in NJ
David Yoho
No help here for a review but some thoughts that may be helpful.
First, you didn't say what brand of gun you had. Were you happy with it? What features are important to you? Basically, if you get one that shoots the length brads you use most, any of the main brands should be fine.
I have an Accuset (no longer available but was made by Senco) brad gun and a Grex 23 gauge pinner. The Grex line is like a Cadillac and carries a steep price but a great gun. Porter Cable and Senco are probably bigger sellers and are easy to find fasteners for locally. All will do a good job, so it really boils down to cost, availability of fasteners, and how well it feels in use.
del schisler
i have the pc-200 i belive ts the number of it , of course it is porter cable, the new one i don't like it fell's junkey not very good made, it work's tho, i had to buy one when i was waiting for a part for my old pc model, it is made very well and work very good, if you can get the older version you will be happy with that one, i would look on ebay for the older version, if it were me , once in a while i put a couple drop's of oil in the air input for lub in the inside . good luck
I've had and used a Senco Finish-Pro-25 for a number of years. Fine gun, no jams after several thousand nails, 2 power settings (will sink a 2" brad into Oak), oil-free. Not Cheap.
If, however, you're a member of the "put-a-brad-in-it-till-the-glue-dries" school of woodworking, look into a Grex 23ga pinner.
Re: Hitachi is top of the line...
Rick L
I spent 8 years servicing machinery and air tools. Hitachi was the gold standard for contractors who use the tools daily and hard. Personally I have been buying HF nail guns. For $20 you can get an 18 ga combo stapler/nail gun and for $20 get a two year replacement contract. Typically it's $35 an hour for a repair technician to fix a gun. So buying a tool for $20 and if you have to toss if it breaks a couple years down the road it's a no brainer...
kevin
I have an older PC BN200 type 1 (now there is 200A, B, and C).
It says 3/4" to 2", but I've used 5/8" brads just fine (bird house, runners on crosscut sled)
I don't use it a lot, but it's never failed, and if it did jam, the quick release would make short work of it.
I keep eye-ing the B and C models though. Mine does not have a depth adjustment -- the manual just says adjust air pressure (70-120). My compressor cycles at 100, so that's where I try to keep it set so as to keep the most consistent pressure.
In your search, if you figure out the difference between the BN200B and C, let us know. I did some reading last eve, and the best I can tell is the C is magnesium body and the B is aluminum. The B seemed to have a couple other features though, and sells for about $10 less. They are both inexpensive, 59 and 69 from what I see.
Fun little tool for sure. Let us know what you go with.
PS -- anyone have a suggestion on how to add a "no-mar" pad to mine? I did not come with one.
