Questions, Cutting dovetails with Leigh Jig?
I have an older Leigh Jig. Not the current generation. I use it just often enough to be bad at it. I bought two routers for the purpose of leaving them set up to make future use easy. Somehow life gets in the way and I end up using one or both of the routers for something else in between dovetails. Getting ready to cut nine drawers of various sizes. The stock is thinner than my usual half inch. Trying to wrap my head around it again.
Does the bushing size matter? I have pair that are about a half inch in diameter, but stumbled across a note in the book to use smaller ones with the smaller bits. I do not have the new adjustable one. It seems to me that the size is not critical as long as they are the same.
(I was watching a video on you tube and guy said I am starting by cutting the pins, but there was a note on the screen that said "He is actually cutting the tails." and at that point, my head exploded. For the rest of the video he would say "tails, I mean pins" or "pins, err tails" or a Pins uhh yeah pins". I just got more confused. )
Any help would be appreciated.
Re: Questions, Cutting dovetails with Leigh Jig?
need more information
Dick Coers
Are you cutting through or half blind dovetails? What size bits? Straight and dovetail bit, or just dovetail? I guess you don't want to read the instructions, or are you just looking for tips?
Jack Guzman from Maine
Barry,
When I started learning cabinetmaking I looked into the dovetailing jigs available. So much confusion! I got a little paperback book on handcutting dovetails. When I cut my first one I was so surprised at how easy it was I laughed. Save yourself alot of headaches and money and learn how to cut them by hand.---Jack
Re: need more information
My parts are 3/8" thick and I am using No. 75 - 8 and No 140 - 8 bits. The bushing I put in is 7/16" in Diameter.
I am reading the instructions and looking at You tube videos. I have done this before but its been a while.
The guide in the back of the book lists these bits for this thickness. Not much reference to the bushing. that's why I was wondering what bushing to use. The 7/16" is smaller than the 1/2" I used in the past and I am trying to figure out the effect.
Mostly looking for tips.
Re: need more information - All righty then...
Tom
I don't think the bushing size maters, but the bit size does, if you want proportional parts. The thing is that if you go to thin stock you have to withdraw the bit further. If you are using a large bit I guess you could end up taking out the bushing depending on the wall thickness, and it's downward projection. But if everything turns well in the set-up, nothing is cutting into the jig or bushing, and the layout has the look you want, I think the actual cuts should fit together.
The parts are described thusly. The "tails" are the part cut by the angled/dovetail cutter, the "pins" are cut by the straight cutter.
MOST IMPORTANT POINT:
Particularly if you are doing a lot of one-offs, cut the tails first. Then set the jig so that the board thickness marks are tending towards the next size up. Then run the pins with the straight cutter. You need a good registration mark for the board position, I normally just draw a clean line with a pencil. You can now remove the board and try for fit. Then replace the board and take it down a touch until you get the correct fit. Then run all the pin boards at once. This because the fit of the parts is only adjustable in the pins with this type of jig. Be sure when you are returning your part for a cut, that you have a meaty enough fitting cut lefte, or well enough returned the board that you are trimming both sides of the pin all over with the fitting cut, or you will not get a true result (this normally isn't a problem). But you have to both return the board in position, and take enough of a cut that the pin is fully worked.
Beware that one side of a box (and the side opposite) will presumably be all pins. This side has two ends. They are right and left relative to the dovetail ends they intersect. If you have your geometry such that each joint has an offset (error of the corners not matching perfectly so the whole will not lie flat), it will not net out during assembly, so take care to see to it that you are creating centered joints. If you are making two/three sided pieces/boxes, you can normally plane a discrepancy out.
Spend some time sorting out how you approach the wood, basically you go clockwise, but there are scores also. Read and understand the book on cutter path, and you will not have tear out. Even though the joint does not require a scribed base line, I normally use one. In some cases it looks better, and it protects against tear out.
You need sharp bits.
With each router decide what the out side is. If you rotate the router as you go through the cut, then your only hope is that the bushing is dead nuts centered, which it often isn't. So decide on an out side and always keep that side facing your body squarely.
Check to see if the bit has lean.
That's about it. It's all common sense.
Thank you Tom
That was well thought out and I appreciate the time it took for \you to think it through and type it out.
I am working on drawers for a chest. There are nine, three of one size, then two, two and two. (Lets hear it for graduated drawers.) I have had the Leigh jig for at least five years, but I use it less than once a year. My original thought was that I would buy two routers and dedicate them to the jig, along with the bushings and cutters, and that I would ALWAYS use half inch thick stock for drawers. Sounded like a plan. Pretty much none of that worked out. I "borrow" one of the routers once in a while and the stock thickness changes.
Thanks for the help. Now I just have to screw up my courage to the sticking point and do it.
Cutting Dovetails by hand.....
is on my bucket list. In spite of having this fine jig and bits and routers, I have the sneaking suspicion that REAL dovetails are cut by hand. In fact, I bought a dovetail saw forty odd years ago with the intention of using it. Along the way, someone I rented a room to ruined it, using it as a bone saw on a deer carcass, but I still have it and it taunts me. Someday I will buy a newer better version and give it a go. But I don't think I am going to start now with nine drawers to do. Thanks for the encouragement.
Re: Thank you Tom
David Yoho
Barry, I have the newer Leigh jig. Like you, I don't cut dovetails often enough to remember what I did the previous time. So, I always prep extra stock in the thickness I'm using to use for setup of the jig and router. This is the best tip I can pass along.
Re: Thank you Tom
Tom
I cut 99% of my joints by hand, I have hardly used the Leigh. It's Canadian made, which at the time I bought it pre LV industrialization, was rare. At the time you couldn't really buy a full set of tools to cut dovetails, from pretty much anyone, goodness knows I tried. I even complained to LV about it. And there was less info. So my best guess was I wanted to finish some projects, or get a method that actually worked without an experience like scratching nails on a board.
If you are making half blinds, it works fine, but it isn't a fully real dovetail, you could I guess cut the dovetail boards OK. For throughs, it cuts real dovetails, in fact they are probably more real since the Leigh pretty much produces perfect joints, and that is hard to do by hand. Not so much because of poor craftsmanship, but because the surface geometry of saw cuts may be less perfect, to push a point.
The key to making hand dovetails is practice. And I don't mean years of hacking away. Relatively few sessions of sawing vertical lines freehand for feel, sawing vertical lines that fall next to a line (not twisted into place). Use easy wood like pine, use minimal layout techniques like the Klauzs method. Make sure your stance is natural so the tools fall right on the line. Etc... Practice basics. Bring it together. While some would say practice is boring, it is an environment where you don't have to worry about destroying an expensive project, or looking bad to yourself. Remember that woodworking is a craft that by definition could be taught to most anyone who fell into it's grips. If you toss out all the grunt work an apprentice had to do to ear his place, the actual educational time to learn basic sawing or chiseling must have been pretty minor.
Another thing that helps with confidence is doing everything rough by hand. Pull out the hand saw, and not the skill saw etc...
Thanks to all, they are done.....
Spent part of the morning setting up the jig and part of the afternoon cutting them. Cut one practice one to get the jig and routers dialed in and them cut them. Nine drawers worth. Various widths and depths. So that's Nine drawers, 36 parts, 72 ends. For somebody both ADD and dyslexic it was tedious and boring, but its done. Tomorrow I probably will get to assembling them and tuning them.
Thanks for the help. Once I actually got into it, most of it came back.
