LEDs for a lamp
LEDs for a lamp
LEDs for a lamp
Tom
I want to make a light like this:
I am not copying the design, it will be "ike this" in that it uses a cascade of small lights to supply the overall illumination. So the specifics I would like to address are:
- Multiple bulbs, say around the 15 what incandescent level. Except I want them to be LEDs
- 12V
- Preferably cheap or chinese, since I am in Canada, I want to get this stuff off Amazon or direct from china, etc..., so while I will have to source them, keep in mind they can't just be exclusive parts for an Ohio class nuke sub.
- The individual lights need to be wireable, so that I can set the separation of the parts, though if someone knows a smart way to use strip lights given that need, I am all for it. If the leds on the strip will well enough separated, or the is a way of bypassing certain bulbs, that would be a possibility.
- The bulb will be shaded by the wooden parts, but it will be visible, so it needs to be clean looking.
- It would be best if everything could go in the lamp, but I suspect an external transformer, rectifier, etc... will end up being used.
Any idea of what kind of parts would serve
Re: LEDs for a lamp
Re: LEDs for a lamp
Doug
Tom
You should look at meritline.com .
Doug
Re: LEDs for a lamp
Re: LEDs for a lamp *LINK*
John McGaw
You are in a golden age of LEDs -- they are everywhere in every size and style you might need. LED replacement bulbs for autos might be suitable for some projects. LED tapes can be pretty useful even in small pieces -- all of them are designed to be cut apart at designated intervals and if the resulting pieces will fit into your project then you are good to go and the high-density ones put out a surprising amount of light and come in several color temperatures.
I just bought three 3" LED can lights yesterday for my bathroom remodel. I was surprised to see Lowe's carrying such units. Of course they would not be suitable for your project but I thought I'd mention it in passing.
http://www.superbrightleds.com/cat/component-leds/
Re: LEDs for a lamp
Re: LEDs for a lamp
Robert Fuller
I think this is what will work best for you:
http://www.radioshack.com/product/index.jsp?productId=2062559&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032233
This is the socket with reflector, and you then buy the bulbs to plug into the socket. This gives you the added benefit of changing the color of the bulbs for the holidays if you desire!
Re: LEDs for a lamp
Re: LEDs for a lamp
Tony - Memphis
You might look at the LED strips at Lee Valley. An external transformer will be required. Perhaps you could build it into the lamp somehow? You can buy similar products on eBay. I used the Lee Valley products for my kitchen. Worked great. They also sell dimmers.
I would probably wire individual component LED's. You could use a wall wart transformer to provide say 5V (quite common and cheap - buy one that is regulated and provides enough current). Once you picked the LED's, you would need to calculate the resistance required for each LED - that is easy and there are calculators online to make it real easy. No dimmer with this setup though.
If you really want to get creative, use a mini Arduino to control the LED's. You could add a dimmer and even different effects, control LED's individually or as groups, etc. Would be easy to add colors using RGB LED's etc. I use a similar setup to control my Christmas "candles" in our front room each year. The Arduino makes it easy to produce a flickering candle appearance.
That is a neat lamp. You could really have some fun with it. You might need o do some experimenting to get the look you are after. LED's are very directional. I have used all sorts of methods to diffuse them including the roller ball from a deodorant bottle! I cast my candle flames in a colored resin to get the color I wanted. That is pretty easy too. You could cast your own colored lenses.
Tony
